Chinese Chestnut - good for turning?
Jim K in Trappe PA
>I have an opportunity for some free chinese chestnut. The tree is very large, so I could get some good size blanks, but I have never seen the wood before. Does anyone know if it is any good for turning? What other wood is it like? (I know American chestnut is similar to oak).
Thanks,
Jim
Re: Chinese Chestnut - good for turning?
Rick Allen
>Nice wood with wide growth rings, There is a lot of visual action to this wood. The wood checks quickly. I have seen the tree cut down and within 20 minutes the freshly cut wood starts to check. Plan on splitting the wood through the pith as soon as you can. Rough as much as you can as soon as you can. The color, grain and weight make nice bowls. The wood turns with a good bit of fuzzyness, sands fairly easly and takes finish well when dry.
As with any wood, when you get near the end of your supply you will have learned a lot about the wood. You will also wish you had more to turn.
Good Luck
John H WIlliams
>I believe this is Chinese chestnut, although it was sold to me as American Chestnut. This 14 inch diameter platter is from a crotch and the wood is highly figured because of its location in the tree. I think it may be Chinese Chestnut because of its size. American Chestnut never gets very big any more because of the chestnut blight. This wood had been kiln dried and the only pieces usable were a few slabs thru the crotch, and these had many checks that had to be avoided. The wood was harvested near Philadelphia, PA
A wonderful wood to turn.
RevDoug
>You are right, John. Am. Chestnut has grain that looks much more like oak. Hard to find it that doesn't have worm holes in it too. Good looking stuff either way. You did a nice job with it.
Turn 'em round,
Thanks all!
Jim K in Trappe PA
