While the garage was dirty...
Mike Hamilton
>I figured I ought to finish another rough turning. Maple with some spalt and some ambrosia stain, 8 by 2.5 inches, no finish yet, needs some hand sanding touch up on the rim (kinda backed into a little detail there).
I need some ideas on a finish that doesn't hide the splat/ambrosia. Any hints to share?
Comments on form are always welcome.
Top:
Re: While the garage was dirty...
Re: While the garage was dirty...side
Mike Hamilton
Re: While the garage was dirty...bottom
Mike Hamilton
John Veerkamp
>Mike, if the bowl is for display only I like using just a good quality paste wax. I wax the piece after 320 sanding and sand with wax thru 600. Makes a lovely soft smooth surface that really shows off color & pattern on boxelder and other spalted woods.
Nice bowl,
John
Jennifer@Indy.USA
>Nice one Mike!
You did a great job on the shape. I just use my regular Watco on Ambrosia....never had a problem with it.
Jen
Mike Hamilton
>Thanks John,
I imagine this piece will be more centerpiece than utility piece.
Do you sand with wax -
1) on the lathe or off?
2) power or hand?
3) at what point do you buff the wax off, each grit or at the end?
Does Trewax qualify as a "good" wax for this purpose?
Regards,
Mike Hamilton
Plainfield, IN
Tung oil will really pop the figure !
OB O'Brien
Re: Won't oils darken?
Mike Hamilton
>and will that lessen the contrast between the abrosia, splat and normal wood?
Regards,
Mike
Just a little bit
OB O'Brien
Re: Watco Wiping Poly won't ......
Jamie Donaldson
>.........cause as much of an amber color cast as Tung oil. The new wiping polys are quite nice additions to our finish arsenal, especially useful for those times when we want minimal color change with a durable, easy to use finish.
John Veerkamp
>Mike,
I use Trewax.
Sand on the lathe by hand unless the piece is too deep to reach the bottom.
I sand without wax until the last few grits.
Then I put wax on the sandpaper and apply as I sand. I buff with an old tee shiet after the last sanding only.
John
robo hippy
>After years of using walnut oil from the grocery store, and beeswax on top of that, I switched to the Mike Mahoney products. Nice and warm for the colors. The oils will darken the wood a bit, but it does seem to help the colors last longer. It is an excellent finish for a utility bowl that you intend to use daily. For my art pieces, I like Deftoil. It has a bit of urethane in it so it doesn't dry out much for a long while.
robo hippy
Carole Valentine
>Mike, I use a wash coat of thinned lacquer (50/50) applied and wiped dry before applying an oil. This is something I think I learned from Russ. It keeps the oil (I use Waterlox) from darkening the wood so much and evens out the pentration on end grain. Some pieces that I did when I first started turning, were done with just straight Watco and they have darkened and yellowed a lot.
Bill Hale / woodspinner
>While on the lathe I use 1 coat of aersol spray spar varnish sanding sealer. Spray on and wipe off to a high gloss at about 800 rpm. I follow with 2 coats of aersol spray spar urithane for utility things. Hand buff to wanted gloss or lack thereof.
Little color change and the spar is great for UV protection.
Bill in Casa Grande, AZ.
Devo
>I do the same thing, 3x Watco, dry for a week, under Coats of Satin poly or 3 coats Waterlox tung oil cut with Turpentine 2/3's first coat, 1/3 second, and full strength Waterlox for the final (see Russ's finishing techniques) Its bulletproof.
- Devo
