Veritas Scraper Burnisher for Woodturners
W.C. Turner
>Hi Everybody,
I finally got one of these burnishers, with the 2 rods, 1 ground at 10�, and the other rod ground at 5�
1) Does anyone know, if I would be correct in assuming, that the smallest rod is the 5� rod??
2) How close does one need to be to the 75�or 80� scraper bevel to burnish on the 5� rod, and/or, to the 70� or 75� bevel for the 10� rod? In other words, would you have to re-grind the scraper bevel if it doesn't fall into the 75�-80�, or 70�-80� category?
Hope that's clear as mud.
Thanks,
W.C.
Email: Remove 2
Re: Veritas Scraper Burnisher for Woodturners
Bob Fawcett
>WC,
The angle is measured as the deviation from 90 degrees, so the 5 degree has the larger diameter at the top. The 10 degree is smaller.
You should be able to burnish anything with an angle of 85 degrees or less. The more you deviate the greater the angle between your scraper and the burnisher.
Clear as mud as well, I know.
W.C. Turner
>Bob,
Thanks for clearing that up for me.
Have you had one very long?
Wonder why veritas doesn't specify which is which?
Thanks,
W.C.
Forgot...
W.C. Turner
>to add, I bought it from Woodcraft. I called to ask this question. They didn't know either. They assumed as I had, that the 5� was the smaller one.
W.C.
