Pocket Butler
Pocket Butler
Pocket Butler
Gordon Seto
>This is an off-center turned pocket butler. Instead of a bowl to dump everything from the pocket, I like to have separate areas for wallet, keys, pens and loose change. The wood is maple with spray lacquer. In order to separate to round base and the 4 sides; I applied gold leaf to the bottom. The majority was turned. The bottoms of 3 shallow bowls were blended with Foredom.
All suggestions and comments are welcome.
Re: Pocket Butler
Re: Pocket Butler (Side view)
Gordon Seto
Re: Pocket Butler
Re: Pocket Butler (Bottom view)
Gordon Seto
Re: Pocket Butler
Re: Make pics smaller...
>Other than that, it looks like an interesting concept. Some novel turning there.
Re: Pocket Butler
Michael Stadulis, in Gloucester County, NJ
>Gordon,
It appears that you use DT jaws to hold your work instead of a tenon. What is your trick.......just very light cuts? Everyone seems afriad of the piece splitting w/ a DT jaw.
Mike
Re: Pocket Butler
Re: Pocket Butler
Barry Turner
>You might want to re-think the the lacquer finish in favor of oil. The lacquer may chip from the keys, etc. Neat project.
Re: Pocket Butler
Gordon Seto
>Mike,
This was turned on 9 centers. The offset centers were 2" to 2-3/4" from center. I used a glue block with the Nova faceplate ring and SN2 chuck to turn the off centers. It was extremely unbalanced. The lathe was walking while I was turning.
The DT at the bottom was used to turn away the glue block and blend in the bottom. The diameter of the DT is relatively small as compared to the size of the foot. There should be plenty of wood to resist the splitting.
I hope this time I can size the picture of the glue block correctly.
Gordon
Re: Pocket Butler
How'd you do that? Betcha Can't Do It Again!
Barry Turner
