Boiling wood
Boiling wood
Boiling wood
Jim King
>We are currently testing various drying forms of rough turned boiled bowls. Here are the results of a group of rough turned peices 10 days after boiling. As you see on the graph we had a moisture content of 100% when cut until fresh rough turned. 10 days later all have dropped at the same time drasticly to 15 to 25% moisture content and seem to have stabilized. Dont ask my why but this is how it worked out. Not a one cracked. Now we will throw them into the lumber kiln for a week and get them down to 6% or less.
We are doing this with other forms also but the process is much slower so when we get results we will publish them.
Re: Boiling wood
Re: Boiling wood
Gary Evans Tallassee, TN
>Hi Jim,
Not to criticize your work, but I'm curious as to how you are measuring the moisture content. It's rare to see any wood with exactly 100% moisture content when green, yet all of your woods start out at 100%. Also, there is usually some difference in moisture content between sapwood and heartwood.
Gary
Re: Boiling wood
Re: Boiling wood
Jim King
>Gary: Our Moisture meter as many do whenever the moisture content is over 50% will read 100. I dont know why but thats the way they work.
Re: Boiling wood
Re; boiling wood
Mike Nelson
>Jim, I take it you boil after roughing out. How long do you boil? totally submerged? Just plain water? The graph looks very promising, no cracks! Will you air dry any for comparison times and those of us without kilns? Thanks Mike
Re: Boiling wood
Re: Boiling wood
Ed Karch
>moisture content is the weight of the water in the cells and interstices of the wood expressed as the percentage of the oven dry weight of the wood. You are measuring water weight not volume and not wood.
