making a hollowing tool -- beginner
eliot d
>I managed to make a simple hollowing tool by drilling a small hole at an angle in the end of a rod and using CA glue to fasten one of those 3/16 bits in the hole. The problem I had was grinding part of the square bit into a round tenon so it would fit into the hole. What I did was to spin it in a drill against my grinding wheel; but that quickly wore a groove along the edge of the grinding wheel.
Is there a better way to grind the round tenon at the end of a square bit?
Can I use a drill bit next time instead of the square bit?
How about part of an alan head wrench?
Also what's the best way to form a swan neck shape in a rod? And what's the best rod material?
I have numerous professionally -made hollowing tools, but they are too large for the current project. I'm trying to hollow through a 3/4 inch hole.
Post Response Read Prev Ms
Re: making a hollowing tool -- beginner
Re: making a hollowing tool -- beginner *LINK*
Gary R
>You can pick up a low cost angle grinder from Harbor Freight for under $20.00. They work great for occasional use. That will allow you to hold bit in a vise, and grind as needed.
As the rod for the hollowing tool will never have an edge, you can use anything. Standard steel from Big Box should be fine. You can secure in a vise, and heat with a torch (Mapp gas works the best as it is higher heat). Wear some heavy gloves, and you can bend as needed.
I would also recommend the following book - loads of info.
http://www.foxchapelpublishing.com/productdetails.cfm?PC=1882
>Eliot A 3/16" cutter will almost exactly fit a 1/4" hole. You can just drive it in. I knock the corners of very very slightly so it's a firm fit and just put some CA glue in. I also have some installed with set screws but if the setscrew sticks out any it gets in the way. The CA works fine. If you need to get it back out just heat it up with a propane torch and pull it out.
Paul Porter
Paul Porter
>The hollowing tools I use are home made. Here is a photo of the tools I use for smaller (up to eight diameter and six inches tall)hollow forms. I use a swivle head on the one tool, but could easily drill a hole in the end to insert the cutting bit.
My hollowing tool web page
Richard Allen
Richard Allen
>Hi Eliot
Do you attend any of the "skill enhancment" workshops the CAW has?
If you contact CA with your delimia he may be willing to help you out. CA uses a hydrolic press to make his swan neck hollowing tools.
If you do attend a workshop and you let CA know what you want to make he will very likely be ready to help.
Good luck
Re: laser setup
Dinyar Chavda
>Hi Paul:
I am interested in finding out moreabout the laser set-up that you have in your pciture. Could you provide a bigger picture(s) of it, as well as any details that might help in making one. As Denzel Washington said in the movie, Philadelphia, "Now explain it to me like I was a 2-year old!".
TIA
Dinyar
Paul Porter
Re: laser setup
Paul Porter
>Dinyar,
I have changed my setup since this photo was taken. I need to photograph my new set up. I had a six inch long piece of half inch steel bar welded to the tool right at the joint with the out rigger to get rid of the wood block next to the handle. The laser holder is made from scrap wood, half inch aluminum tube, carriage bolts and plastic knobs. I'll take some close-up photos of it when I get home work tonight. I think photos would explain it easier than I can.
what brand lazar?
>I was really fed up with my lazar the last time I used it. The switch is the problem but fixing that would be a real headache. The light intesity varies due to vibration and I'm pretty sure it's in the switch. This is a cheap that I'm using.
>I have made a few of these. Yes you can use a drill bit. I like John's idea of inserting the square HSS in a round hole. I will give that a try. Another thought is to got "the other way". Start with a round rod of HSS and then grind the business end square or to whatever shape you need.
Some people have made very small ones out of Allen wrenches.
I also suspect you don't have to get terribly excited about tempering and hardening. I made some out of oil hardened drill rod that came annealed or "soft" and then heated the tip and held it red hot for about thirty seconds and quenched it in oil. The claim is that at that point it could be glass hard and shatter. I whacked it on a piece of cast iron a couple of times and it did not break. (This passes for highly scientific testing in my shop.)
Visualize where the cutting will occur. That's the only part that needs to be sharp.
Bob Fawcett
>Eliot,
All of the advise you have so far is good.
You could also round your bits by hand on the grinder. Just hold and twist it with your fingers against the grinder wheel. Its really not that hard to do. Once you learn to do it by hand, you can grind any square bit round, or round bit square.
eliot d
>Richard,
I do sometimes go to the skill enhancement workshops, (held on the second Wednesday and last Tuesday of each month at CAW at the Bryant School in Alexandria, VA. -- for those in the Washington D.C area) . And , of course CA can make just about anything, But it's sort of,
" Hey mom look what I did! ". which is to say I want to give a try myself. I succeeded in making one already, but that rod was already bent . What I've learned so far is that for rods of standard ( hardware store) steel up to 3/8 inch, I can probably bend it the way I want with just propane. Larger diameters apparently will require mapp fuel. All this because my larger hollowing tools are too big to go through a 3/4 inch opening, which is what I'm currently working on.
