mini goblet
mini goblet
mini goblet
>I had some fun last night. I made new mini tools from finishing nails and turned this goblet. It's really cool. The wood cuts just like normal except your feed rate of the tool is greatly reduced. As you can imagine the cut might only be .025" deep for the cove at the top so you have to be pretty easy with the tool. The cutting angles of the tools are different and some cuts work better in a scraping motion. For example the only way I could get a clean cut across the bottom edge was to use the skew on it's side. At any cutting angle I tried you raised a burr on the edge. This is ebony and has some rather large (on this scale) pores. I'm going to try another wood this weekend.
I'm going to have to make new tools out of better steel. I used finishing nails and even hardened them but they just don't cut as well as my jewelers screwdriver. At this maginification you can see the tool grind marks and you can really tell the difference in the steels.
I made a goblet about 1/3 smaller last night but when parting off the base it fell to the floor never to be seen again. I need a way to catch the goblet so I came up with an idea. I will chuck a piece of 3/32 brass tubing in my tailstock and just before I make the final parting cut I'll slide the brass tubing over the goblet. That way it will simply go into the pipe as I cut it off.
Re: mini goblet
Re: mini goblet
Carole Valentine
>How in the world could you see what you were doing, John? Jeweler's eyewear? When I was fooling with making micro stuff that was one of my biggest problems (as well as losing them on the shop floor!) and I wasn't getting nearly as tiny as yours. Blackwood seems to have smaller pores than ebony. You also might try the nuts.
Re: mini goblet
Re: mini goblet
Gary R
>Try putting a small piece of screen or cheese cloth over the end of your vacuum. Catches minis pretty well before they begin their journey to never never land on the vast wide open shop floor!!
Re: mini goblet
Re: mini goblet
>Carole I bought a cheap stereo microscope off ebay. I reached a point where my turning skills were better than my eyesight. Tagua nuts don't work for goblets. The stem is too weak. I also tried turning rice, same problem.
Re: mini goblet
Turning Rice!
Jennifer@Indy.USA
>John,
Deep breath...exhale....
get back to trees!
Cute little goblet!
Re: mini goblet
Rice????
Carole Valentine
>You have got to be kidding, John. I think you need counseling! LOL Or maybe you need wood - should we send you some before you lose it completely? ;)
Re: mini goblet
Re: mini goblet
Wally Dickerman in Arizona
>Not nearly as mini as rice, but I've watched Bonnie Klein turn goblets out of small aluminum aircraft rivets. Came out very well.
When you live in Seattle where Boeing is, aircraft surplus items are easy to get.
Wally
Re: mini goblet
Re: Rice????
>Carole Gosh at this size one log would last a lifetime. My original goal was to turn a goblet smaller than a grain of rice. That was easy so I decided I would turn one from a grain of rice. That didn't work. I may try soaking one in CA glue just to see if I can do it.
Thanks for the tip on Blackwood. How much would it cost to buy a chunk big enough for this goblet. $10 maybe :)
Re: mini goblet
Re: mini goblet
>Wally haven't made a goblet from aluminum but did make some mighty small parts for a camera out of brass using handtools and the wood lathe.
Re: mini goblet
Leo Van Der Loo
Re: mini goblet
Leo Van Der Loo
>Boy that's small John, I wouldn't be able to see good enough anymore I'm afraid, what are you using for a tool rest John, got to be pretty slim to get close enough.
And any fine finger movement would start to get rather course also, just muscle squeeze will have do I suppose ???
Have you tried turning some bone ?, or is that to brittle also ?.
And I suppose no sanding needed if you don't give the microscope to look at it , (grin).
I do want to try something really small, just to see how small I could go, and you put up a real challenge here.
Very neat John.
Have fun and take care
Leo Van Der Loo
Re: mini goblet
Re: mini goblet
>Leo I drilled the end of my tool rest and pushed a 1/8" roll pin into it. That let me get close enough. The bigger tool rest gets in the way somewhat so I may make a small 90 angle tool rest that sticks out of the top of a tapered 1" bar. It was really difficult to do anything with the lip of the goblet because I couldn't move the tool rest.
There are a lot of little problems I need to solve to make this process go smoother. After I see how small I can go I will probably go back to doll house size and just add finer details to my "bigger" turnings.
Re: mini goblet
Keith Tompkins
Re: mini goblet
Keith Tompkins
>Hey John, that would look great with a spiral stem! LOL Neato!
Re: mini goblet
Re: mini goblet
>Keith I was thinking spiral with contrasting wood inside. Maybe the next goblet will be segmented.
Re: mini goblet
Steven Antonucci
Nice bit of macro photography too
steve antonucci
>"why do men climb mountains?"
Because they can...
"why do men try to turn rice?"
Because they need a girlfriend (would have said a hobby, but you've already got one, and it didn't stop you from trying... :-)
Steve
Like the camera work too, John!
Re: mini goblet
Re: mini goblet
>John, I noticed Lowes has finishing nails made for hardwood. I did not fool with them, but I assume they are harder and perhaps of better steel that the others. If you want some and can't find them locally let me know. I'm sure I can afford to send you a lifetime supply.
Re: mini goblet
Keith Tompkins
Re: mini goblet
Keith Tompkins
>John, I wouldn't be a bit surprised!
Re: mini goblet
Ha-You nailed it Steve. :)
Re: mini goblet
Re: mini goblet
>Barry As an ex camera repairman I have lots of jewelers screwdrivers laying around. I went home and made a smaller set of tools out of a couple of those. Now I'm back on campus shooting some sort of politician hand shacking BS thing so I won't get to try them out until tomorrow sometime. Thanks for the offer.
Re: mini goblet
Re: mini goblet
Bob Fawcett
>John,
I can send you a supply of rivets if you wish to try this. Working for an aircraft manufacturer may have advantages after all. :-)
Re: mini goblet
WOW
e
>How did you get that nickel to be so BIG!!!
Re: mini goblet
Re: stereo microscope
Dinyar Chavda
>John:
I was curious as to how big this stereo microscope is, and how do you attach it and keep it steady on the lathe?
Re: mini goblet
Dennis in Southern Oregon
Re: mini goblet
>I think I will concentrate on coining a bigger nickle!
Re: mini goblet
Wow John
>I remember the first piece you made when you got your new lathe, this one is even smaller! I love the honest look of the toolmarks, dont' sand them away, and the amount of detail you packed in there is remarkable, keep them coming!
Thanks for the chuckle...
Jorge
Re: mini goblet
John, Do You Ever Sleep?
Barry Turner
Re: mini goblet
>Dinyar It's a very small microscope. I attached it to a wooden stand that sits on the floor. I attached it to a bracket I made to fit the rail of my camera bellows. This was attached to another micro focusing rail so that I had both lateral and forward adjustments to the position. It was very hard to move the stand 1/8 or 1/16 of an inch to position the microscope.
I'll have to post a photo because I also have a bracket from my photo studio that lets me tilt it.
I thought about attaching it to the lathe but then figured if there was any vibration at all it would be amplified by the microscope, so I put it on the floor.
