And so it begins.........
Pete LaBelle
>Morning.....
The new JET 1642 is operational in the basement (upgraded a few weeks ago from a 1236), and have been doning some limited turning on it these past few weeks. Slowly getting new tool rests, vacuum chucks, weight boxes built, but stumbled into another needed purchase.
While on site with my friend the part-time tree-slayer cutting some larger chunks of the trunk of a maple tree for me, it dawned on me that my chainsaw only has a 16" bar. This was fine when turning no larger than 12" diameter pieces, but now will be stretching the extents of my saw making larger blanks for the new 16" lathe. Luckily, when the saw was purchased, I asked for the shorter bar of the two offered, so there should be adequate HP to turn a longer one.
CURSE this hobby and the constant drain on the wallet !!! (just kidding, of course).
Pete
Re: And so it begins.........
Barbara Gill, Remlik VA
>Um Pete, you can cut in half any log that will make blanks for your lathe; just go around and saw from the other side too. :-)
Seriously, I have a 16" bar on my chainsaw because often I am forced to hold the saw at unusual angles in the sawmill. An 18" bar was too unbalance for me. It has been very rare for me to have a log that is so large I am unable to saw through it and I have had some really big ones. Keep the 16" bar.
Barbara is right!
Wilford Bickel
>Pete, Barbara is right - I routinely cut 29 - 30 inch diameter logs with a 16 inch saw. I never want a saw with the longest blade that is listed for it. Usually that set up is at minimum power and is nose heavy. Being nose heavy will allow it to drop down when you are moving and risk kick back if you don't have the chain brake set. You should be fine with the 16 inch bar - save your money for the new chuck, faceplate, gouge - uh - you know, all those new things that lathe needs!!!
>OK I'm going to be the odball (what else is new). I bought a 16" husky and purchased a 20" bar to go with it. For most work the 16 is fine but when I'm ripping crotch wood the 16 just doesn't cut. The reason I know this is my 20 chain died and I didn't have time to run to the shop so I just used the 16 to cut up a bunch of wood. the 16 worked fine for all the logs, even ripping them but I really missed the 20 when I started ripping the crotch pieces.
Pete LaBelle
>Yea, I know I can come in from both sides, but tis really nice having a cut surface that is flat, which will be a greater challenge coming into the log from both sides.
Also, with the tip of the bar bottomed out in the log, there is a greater chance of it catching and whipping upwards.
Have other things that will need to be purchased before I probably head down the road of upgrading the saw though.
Thanx for the input.
>You can get a nice smooth cut even going at it from both sides. That is also true about the nose of the bar.
Terry Quiram, Roanoke Illinois
>I am also an advicate for a big saw. My buddy has the largest Husky made with a 36" bar. We can log a bunch with that baby. Besides horsepower one of the benefits of a big saw/bar is that your saw will cut much better if the tip is outside the log.
Terry
