Jet 1236 toolpost lock question
Ken Grunke from SW WI
>The locking screw for the toolpost on my Jet 1236 bears directly on the post, eventually (sooner than later) buggering/boogering/marring/defacing the post and making it hard to move around or remove. Any bright ideas to remedy this, from other 1236 owners?
Hope this hasn't been asked a jillion, BobDylian times already...
Re: Jet 1236 toolpost lock question
>The very first 3520 powermatics had slot milled in the tool post and matching loose piece fit in the slot. The screw pushed against this and was extremly secure. That must have been too expensive to make so they changed it to a screw than had a brass tip. For some reason the screw was hollow and broke a lot(I think it was to make the handle adjustable but I've forgotten). They replace this with solid screws. I don't now why I don't have the dent problem on any of my tool posts. Harder castings I guess.
Since could simply run a file lightly over the tool post to take out the high spots. That's a temporary fix. You could try putting a small brass spacer between the screw and post but unless you fasten it to the screw in some way it would get lost.
On my homemade knock out bar I put a brass tip on. I center drilled the end of the steel. Then on the wood lathe I turned the brass tip so it had a tenon that fit this hole. Then I just epoxied them together. That thing's at least 5 years old and still working fine.
Pete LaBelle
>Had about 2 years on my 1236 prior to upgrading. The locking screw should have a slighty rounded end on it, rather than a cup point like a common set screw. Yup, it marred my tool rests up (both steel & cast iron), but didn't really hurt things too bad, nor did I have to ever file off any high spots. The new 1642 has the same concept to hold the too rest. Just make sure to tighten it adequately, and not excessively. I also make a practice to lube the threads of any frequently-used threaded piece to reduce wear to the screw and the threaded hole.
Often wondered why the housing wasn't split with a screw to clamp it on to the tool post? I don't recall any lathe doing that. Industry uses that trick a lot.
Re: Not an uncommon problem ...
JamieDonaldson
>... with many lathes. I would grind a flat end on the lock bolt that engages the toolrest post- has worked well on some I have encountered. I also removed most of the damaged post dimples with a file- some posts are harder than others and are not so easily damaged.
>John, sounds like you're talking about a keyway cut in the banjo's toolpost hole? And a strip of metal fit into it to take the pressure from the locking screw. Sounds like a good idea, I'll keep it in mind.
Pete, a split housing may seem like the ideal solution, but probably not cost effective for a budget-quality lathe like the Jet.
>Jamie, a flat end on the screw sounds like the easiest and best fix. Less likely to dig in than a round or cup point. If I think about it more, the flatter and smoother the better--not so easy to achieve. I could chuck the screw up in my metal lathe and face off the end, without too much trouble.
Randy Privett
>Ken,
I had a couple like that and I brazed the end of the bolt with a small amount of brass then sanded it flat, best of both worlds, flat and a soft brass end.
Randy
Brad Vietje
Maybe not the answer you hoped for...
Brad Vietje
>Ken,
I also have a 1236, which I suspect is a Monday AM/Friday afternoon lemon -- quite a bit less satisfactory than others have reported.
In my humble opinion, the toolrest/banjo/outrigger is really a very poor design. There's a long story behind it, but it boils down to some engineering school flunkie deciding that they had to provide a banjo extension so people could turn a platter larger than 12" diameter by rotating the headstock and using the terribly-designed banjo outrigger thingy, which is unstable and dangerous, and best suited for a canoe anchor or some sort of homicide or road rage attack. To acommodate this stooooopid design they then chopped about 1-1/2" off the neck of the banjo to give the outrigger room to fit (badly) on there, leaving the banjo about, oh, roughly 1-1/2" too short to adequately support the toolrest, which has to have a longer post to make up for the 1-1/2" that was chopped off the banjo...
Thus, here's my 3 cents on the matter... Grind a flat on the end of the set screw if you wish, which should work fine for quite some time. Even if you don't, by the time you've scored the toolrest post enough to bother, you'll probably want to upgrade the entire toolrest/banjo assembly with one from a Oneway 1224, which many happy users report works wonders, and makes the 1236 a much better overall lathe. I secretly believe that all these discarded 1236 banjo outriggers are the true cause of all the homicides and road rage incidents of late, but I'm still doing the statistical redactions.
My answer was far more costly -- I got so sick of my 1236, I bought a Powermatic 3520-B. I still have the 1236, and may do the Oneway banjo cure along with a few other upgrades to make it a nice medium-sized lathe, but it's just sitting in my barn being punished for now.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Maybe not the answer you hoped for...
>Brad, I KNEW there was something about this lathe that was bugging me, and I couldn't quite put my finger on it. The short banjo! Thanks for the insight. I keep that extension handy to defend myself from the possible rabid raccoon or skunk that might wander into the shop.
I'm happy to say that the lathe doesn't actually belong to me, it's just being temporarily stored in my shop conveniently near an outlet. I'm working for the lathe's owner getting him tooled up for making African-style percussion drums and we had a need for two banjos to hold a long tool rail. Good thing I didn't order another Jet banjo, I'd be whacking my head in regret! Maybe I can convince my friend to get the Oneway banjo, or for that matter, a lathe ;-)
