Finish curing questions
Jack Savona
>A few months ago Russ alluded to the fact that lower humidity is a favorable condition for curing oil finishes.
My questions are:
What other conditions or interventions help speed the full curing of oil finishes?
Can a "curing box" be created to speed up the curing process?
Will accelerating the process have any negative long-term effects?
Jack
Re: Finish curing questions
Pete LaBelle
>My understanding is that evaporation is what happend in oil finishes. Evaporation works better in a dryer climate. Heating is often used in industry to speed the drying/curing process, but I'm sure that depends on the finish being used. I often park a small wood project in front of a forced air electric heater on a low heat constant fan setting to speed up the drying of the finish and it works well. The idea is only to blow a warm breeze over the part, not cook it. Excessive heat may cause distortion to the wood, over drying, etc. Proceed cautiously.
Russ Fairfield
>A short answer to a complex question is that oilo finishes are quite sensitive to temperature and humidity.
The thinners do nothing except carry the oils and resins to the wood where the liquid molecules of the oil will link up by polymerization to form the larger molecules of a solid. Best "drying" occurs when the evaporation rate of the thinners and the linking process (polymerization) happen at the same rate. Ideal conditions are 70F and 70% relative humidity.
Most oil finishes carry a warning on their label that says in effect: "Do not use when it is too cold, too hot, or too wet." You are left to define what is "too". What that is saying is that, if the thinners evaporate too slowly, the molecules get tired before they can link; and if it evaporates too quickly, they never get together to make the link.
Cooler and/or higher humidity will retard both reactions because nothing will happen if the thinner cannot evaporate. Too hot and too dry and the thinners will evaporate before the linking of the finish is complete. In either case, you can end up with a gummy finish.
There is also some heat from the reaction of the finish, and this small increment in temperature is necessary for polymerization. If it is too cold, the linking never happens because there can be no heat.
You da man, Russ!
Jack Savona
>Thanks again for your knowledge and generous input.
