Sanding grits
Sanding grits
Sanding grits
woodturner
>I once heard a formula for grits.
In moving from one grit to another don't jump up half the number of the privous grit.
Example, 120 to 180 is fine, half of 120 is 60, 120+60=180. Is 150 honestly needed then??
120 to 220 is not ok, 120/2=60, 120+60=180 which is less than 220.
Is this something that has been used or heard of by anyone else?
The grits I stock, but may not use the coarse grits always.
80-120-180-220-320-400-600
Is this a good run of grits?
Re: Sanding grits
Ric Taylor
Re: Sanding grits
Ric Taylor
>Yep, I have also heard that theory. The grits you are using are the same ones I use, although I sometimes use 1000 and 1500 also.
Ric
Re: Sanding grits
Re: Sanding grits
robo hippy
>That is the formula that I have heard also. I also keep 100 and 150 grit on hand, and when I need a coarse grit to start, I will use 100. I like the intermediate 150, as kind of a extra because I don't trust myself to get all of the scratches out from the previous grit. I have found it easier and faster to remove 80 grit scratches with 100 then 120, rather than jumping straight to 120.
robo hippy
Re: Sanding grits
Re: Sanding grits
eaglesc
>Formula?
I can only find 220. occaisionally 280,320 and 400 in the Klingspor Gold bargain bin.
$3.00 a lb. is my formula.
Followed up with Micro Mesh.
Re: Sanding grits
Re: Sanding grits
Ken Grunke from SW WI
>I've always wondered about 320 and 400--one of them is redundant, as they are pretty close together. If I had 280, I'd skip 320--but then, 220 is close to 280 so which one to use? The numbering can get confusing.
Re: Sanding grits
Re: Sanding grits
Carole Valentine
>"The numbering can get confusing"
But Ken, that's all part of the scheme! ;) I have some that are 220, then I have some that are 240. Both brands have 180 and 320. Go figure.
