REAL MILK PAINT
What is up with lacquer now?
Dave Lambert
>Is it my imagination or is lacquer being phased out of use. I went to several stores trying to get Deft lacquer in the quart cans and found they only carry brushable lacquer now. I called some auto body shops to inquire about some high end lacquers and was told lacquers are no longer compliant in the state of California. Has anybody else noticed this? Also, I have several pieces I am in the middle of doing a lacqer finish on, but cannot get anymore lacquer. Do I have to go back to spray cans now? Any suggestions welcomed!
Re: What is up with lacquer now?
Bill Hale / Woodspinner
>I don't see any problem with spray cans.
I use spray Varnish and spray urithane, No getting old, no clean up, no solvents just spray a piece and put the can back on the shelf. I never even turn the can over and spray out the tube.
Good turning and be safe
Bill in Dolores, CO.
Bill Crommett
>Dave: If you live in California, it is time to spend a weekend in Vegus and stock up.
Dave Lambert
>Hey Bill,
That is a great suggestion. This could be a great write-off since it would technically be a business trip. Do you think the IRS would go for that?
Keith Tompkins
Keith Tompkins
>HI Dave, Solvent based lacquers are being phased out in favor of ISO approved water-based lacquers. I just attended an industrial finishing seminar on the topic. Water based lacquers and acrylics are the wave of the future. There are new technologies that make current HVLP systems obsolete.
Bill Crommett
>Who can prophacy what the IRS will go for ? Just save your reciepts.
Re: What is up with lacquer now? *LINK*
Mkauder, Phenix City, AL
>Keith,
While agree with your statements about water-based finishes, they are the wave of the future primarily for Hazmat reasons.
The one thing that a waterbased lacquer will not have, is the easy repairablilty of a solvent based lacquer, because it cannot burn itself in to the underlying layers - at least as far as I have read. Thus sanding through a layer would leave a witness mark. Let me know if I am wrong, because I would like to try some.
The reason that I have included this link is that turned bowls, as far as finishing goes, are more akin to musical instruments than furniture. The current move to waterbased finishes was promoted by the furniture/cabinet industry. They needed something that would dry hard, quickly, so that they could ship quickly. Musical instruments are made of thin wood that moves a great deal, and suffers alot of handling. It has to be tough and flexible.
This is a good article though. Let me know what you discover.
Mark
http://www.lmii.com/CartTwo/FinishOverview.htm
Bob Edwards
>Keith, Could you elaborate on this statememt?
"There are new technologies that make current HVLP systems obsolete."
I've been thinking about such a system. Should I wait and reconsider?
Bob Edwards, San Antonio
Gil Jones on Lake Seminole Georgia
>Plenty of Deft spray and brush-on in Georgia.
Keith Tompkins
Keith Tompkins
>Hi Bob, the newest generation of spray equipment is designed to fully atomize the finish/air mixture with as little as 3 psi at the cap. This new equipment is intended for industrial use; for example Boeing has converted to this system.
The system I trialed was made by DUX/AREA, based in Seattle. Each "gun" costs in excess of $1300.00, but generates savings in material because of less overspray; therefore less wasted material. It may not be cost efficient for the small shop or hobbiest to convert yet.
Most of this is to meet new, strict federal limits on airborne VIOCs, (solvents) I can give you contact info in you wish, Keith
David Hammond, in Powder Springs GA
>Hey Mark - I don't have much experience with water based lacquer, but what experience I've had, I like a lot. I'm starting to experiment with Target Coatings WB products, and so far I have been very impressed. I've only rubbed out two bowls with their WB USL Lacquer, but the results have been great - no witness marks whatsoever. Each coat has a great burn in with the previous one. I think there are some luthiers with links from Target Coatings website with pics of some incredible finishes with WB products. Check out the Target Coatings website; they also have a great discussion forum - Jeff Weiss, the guy behind these products often chimes in with great answers.
Ping me offline if you have any specific q's.
David
Target Coatings
Lan Brady
>Don't know for sure, but I spray the brushable Deft lacquer. I was told by a cabinet maker that the can is marked that way becasue of the federal requirments of volitals in the air. Be sure to wear your carbon filter mask.
Lan
Water Based Lacquer review
OB O'Brien
>David; I've been using Target Coatings water based lacquer and varnishes for about 3 or 4 years now. I find they go on quickly, dry quickly and each sucesssive coat burns in nicely. If there are any runs (I never get runs, but heard others do (;^}) you wipe em off with a soft cloth and respray. I usually spray 3 coats with an HVLP gun, let dry, rub out any nibs with gray or white 3m nonwoven pads then buff with a soft wax buffing wheel. The WB varnishes have a higher than normal amount of UV inhibitor which I think helps maintain the color on some of the exotic woods. Either one of the finishes cleans up with plain water. I think its a great product and highly recommend it.
>It is marked as brushable because it has retarders in it to allow brush marks to flow out. These retarders also cause the lacquer to dry slower as a result.
Mark
Re: Water Based Lacquer review
>Well guys, I just may give some of these WB lacquers a shot.
Thanks
Mark
Wilford Bickel
>Keith is right that all of our solvent based finishes are being changed due to the stricter VOC laws. I ran into this with Minwax wipe on poly and one of their chemist's told me that I could "thin" the product with 5-15% Mineral Spirits and 1-3% Linseed oil if the product was performing too thick (wonder what they took out to pass the new reg!). If someone has time (I'm wrapped up and got to go to work!), you may be able to get the laquer manufacturers to tell us how much of what to use to thin the brushable and make it sprayable for small hobby shops that will have very little bearing on VOC release.
Kirk (KC) Constable
>I thought ALL Deft in cans (quarts/gallons...non aerosol) was labeled 'brushing'. It'll spray, though.
KC
Thanks for all the great replies!! NM
Dave Lambert
Re: Thanks for all the great replies!! NM
eaglesc
>For Water based lacquer try Unaxol from Mobey Dick.
They have both spray and brush.
The stuff is just about fool proof.
No, actually it is fool proof, I use it.
