ADVERTISE HERE - FREE TRIAL
First container, what's proper angles?
arw01
>I'm starting to hollow my first form, which will be beverage containers on a boat table.
My spindle gouge is catching as I put it inside to start hollowing out. One catch ripped the piece from the chuck!
On some videos I watched them plunge straight in at the tail stock line, but I get some nasty grabs doing that. I've tried a couple of angles and rolls. Those help, but the chuck feeing grab was on a roll that was working fine for a few seconds.
Thanks
Alan
Re: First container, what's proper angles?
Keith Tompkins
Keith Tompkins
>HI Alan, that technique take some getting used to...I use a detail gouge, made from round stock with a very swept back grind. I suggest, instead of using the gouge like a drill, take smaller increments: a short plunge, and sweep the gouge out towards the rim. then another short plunge cut, and sweep out again. Less nerve wracking that way.
Ken Grunke from SW WI
>Alan, it helps to drill a hole to depth first. Then start at the center with your gouge, taking about 1/8" deep cut straight out from center (perpendicular to the lathe axis). Hold the gouge with the flute at about 9:30 or 10 o'clock, the handle angled away from you a bit, and just pull it towards you with the fingers of the left hand while the right hand guides the handle.
For this kind of hollowing, I prefer the Soren Berger tool but I used a gouge before getting one.
Fred Holder
>Ken Grunke described the right way using a spindle gouge. I find it works best if the spindle gouge has swept back wings. I cut from center toward about 10:00 o'clock and it is best to drill a hole on center and almost to the depth of your hollowing. If you are going very deep, the spindle gouge method gets more flaky as you get deeper.
Better tools for holloing drinking containers; i.e., glasses and mugs. Is to use one of the following tools:
1. The Oneway Termite ring tool
2. The Soren Berger tool
3. The Mike Hunter tool (http://www.hunerwoodturningtool.com)
4. Or a tool I was just introduced to that is made by Jack McDaniels (TEL: 425-486-9205). This is similar to the Hunter tool in that it uses a carbide disk as the cutter, but has a 3/4" shank that tapers down to the size of the 3/8" disk. Jack mills a flat on the shaft to make the tool set at 45 degrees when approaching the wood.
All of these tools work very well when hollowing endgrain. The Oneway Termite and Soren Berger tools are available from Craft Supplies USA. The Hunter tool is available directly from Mike Hunter or from Woodcraft Supply. Jack McDaniels tool is currently only available from him directly, but Packard Woodworks is considering handling it in the near future.
If you have several of these containers to make, I would suggest investing in one of these specialty tools. Both the Hunter tool and McDaniel tool use carbide cutters that do not have to be sharpened. Eventually, you throw away the cutter and install a new one. This is something fairly new to woodturning.
Re: Mike Hunter tool website *LINK*
Ed Moore
>Fred,
You left the "t" out of hunter in the URL for Mike Hunter.
I wonder if one could get one handle and both cutters from him. I've pushed the tool-buying a little lately.
Ed
Mike Hunter Tool
