Pecan platter
Roger Smith
>Also finished a pecan platter about 13 inches. Turned and finished green.
Roger
Pecan platter
Roger Smith
Roger
Re: Pecan platter
Barbara Gill, Remlik VA
>That is really a nice piece of pecan. Is there ingrown bark in the center? Often with pecan there will be. How did you keep it from warping since it was turned from green wood?
It does have a bark inclusion
Roger Smith
>Barbara, it does have a bark inclusion that goes almost all the way though to the back side the full length of the bowl. This piece of wood came from vary old tree downed by hurricane Ivan 2 years ago. I noticed the void when I sectioned the tree and made sure that I cut this piece in a way I could use it.
I decided to finished the platter green and let it warp. I didn't think it would hold together to allow it to dry and then finished turn it. If it cracks now, I will use some copper wire or something.
It been 3 weeks and the diameter has not change. There is a little warping next to the inclusion on each side. I know that it will warp eventually. I did not weigh the bowl, but by feel it has lost several ounces already.
I have several pieces that has beautful color and is filled with birdpeck left to rough out.
thanks for the comments,
roger
Re: Pecan platter
E Tabachek
>Is that REALLY Pecan??? I don't know Pecan or how to tell it apart from Hickory, which I am told it resembles. Maybe someone can help me out. I have some boards that are supposed to be pecan that are creamy white to light tan in color with an open grain (ring porous. Looks a lot like ash. Pecan is not usually found in my area; does not grow here and the wood dealers here do not sell it.
Thanks, Ed.
Re: Pecan platter
Roger Smith
>Ed, yes it is pecan. This was an extermely large and old growth tree. This peace came from a large crotch section over 30 inches in diameter and had a large void where the two trunks grew together. The tree came from an estate where I was raised and was part of an orchard in the 50's.
The color in the picture is true. I have some other pieces from the same tree that are lighter in color.
roger
Re: Pecan platter
Carole Valentine
>Pretty piece, Roger. What finish did you use?
Re: Pecan platter
Roger Smith
>Carole, I used Russ's brew a mixture of oil, shellac and lacquer thinner. It was then buff on a bealle with wax only.
roger
Re: Pecan platter
>Often pecan and hickory are sold as the same. I have noticed that Southern pecan (Alabama) looks nicer than our Virginia pecan.
