saw blades into scrapers?
eliot
>I bought a drawer full of old dull table saw (circular) blades a long time ago for $10 bucks. Can any of these be cut up for making scraper blades (the way planer blades can)? If so, how do you cut them?
Re: saw blades into scrapers?
jwoodwright
>Not being wise, have you worked with metal before? This involves cutting and Grinding and requires Personal Protective Equipment. Safety Glasses and Safety Goggles and A Face Shield. Once you've had a metal splinter in the Eye is usually good for a Lifetime. I go for Overkill with all Three (glasses,goggles,shield)...
You can cut the blades with a Handheld Grinder and a cutting wheel. I like to use an Air Fed Grinder as I can use Water to keep the Steel cool. After the rough cutting come the finish grinding and shaping on a stationary grinder. I start wit a 60 grit (3400 rpm), finish with my fine white on the slowspeed (1750 rpm)...
Now, knife Makers do this all the time. Most blades have good steel. You might check out a Nearby Knife Maker... Have fun and be safe.
Mike Nelson
>I have carbide tablesaw blades that last through hundreds of board ft of ash or oak! Has anyone tried cutting out a single tooth with part of the steel as a tennon and using it in a homemade hollowing or scrapeing tool? I have some older wider kerf blades with practically no rake I'd like to try.
Terry Quiram, Roanoke Illinois
>Eliot
I asked that question sometime back and was told that table saw blades were too thin to make good scrapers and that I would be better off using a worn out planer blade.
Terry
>Without a doubt saw blades are too thin. You might be able to make a short thin parting tool. Some people do make card scrapers from them but card scrapers are so inexpensive I could not justify the time to make one from a saw. For thin parting tools there are better alternatives as well. I use Key hole saws. You can buy them for 99Cents at flea mkts. Grind the teeth off and cut it shorter and you have a decent thin parting tool. Old industrial hacksaw blades make slightly thicker parting tools. 1/8" HSS planer blades make excellent parting tools.
eliot
>Terry, I see what you mean about being too thin -- if you think of a long section of blade. What I had in mind, though, was one of those small rectangular scrapers that you attach to a shaft. I recently saw a demo by Andi Wolfe, who swears by that kind of scraper.
eliot
>I was thinking of a small rectangle to put on the end of a shaft. Such a small rectangle would hardly flex at all. But, you're certainly right, now that I think about it It's undoubtedly too much trouble considering the small cost of something like this.
Andi Wolfe came to our club to demonstrate, and she prefers this type of tool for delicate shear scraping.
I'll just buy one.
eliot
>jwoodwright, Thanks for your response. But the others have pretty much talked me out of it, considering that the small rectangle that I have in mind (to put on the end of a shaft) would be inexpensive to buy.
Re: Too much work, when you....
Jamie Donaldson
>.....buy individual HSS shaper blades on the close out bargain table. I made a very useful adjustable scraper on a cold rolled shaft that has been my salvage scraper- works better than any other scraper I bought over the years!
>Elliot I put a larger piece of HSS on the end of a 3/4" rod to use as a shear scraper. It was made from a planer blade. I made the scraper rectangular. I have never liked it as much as my 1/2" flat scraper. The new John Jordan shear scraper is similar to my rectangular scraper in the way that it works but his works a lot better and is easier to control.
>I talked to a couple of blacksmiths about reusing circular saw blades. There was a "distinct" lack of interest on their part. They prefer old files, car and truck springs and various other sources of steel. I did cut up two for thick card scrapers. They work okay for that purpose. I have not tried using them for turning purposes, only flat stuff.
>I know several guys who make knives from old saw blades. they just like the steel. They have the proper tools to cut this steel however so it doesn't take them long.
