Rule of thumb for drive center size?
K. Goring
>Is there a rule of thumb for the size of drive center one should use that is based on the length/diameter of the stock being turned?
K. Goring
Re: Rule of thumb for drive center size?
Walter Ahlgrim
>1 inch drive should be fine for work over 1 inch and less than 18inchs in diameter. On larger blanks it is safer to drill a hole a 1/4 inch larger in diameter than the drive about � inch deep to set the drive into, that way the work will stay on the lathe when you have a catch.
Walt A
>I use a 3/4" drive center for almost everything. It is probably too small for large bowls (even though I've used it for 20"). It is fine for any size spindle you are likely to turn. If I was doing a lot of large spindles I would buy a 1 1/4. I just purchased a 2 jaw 2" drive center for my larger bowls.
I use a 3/8" drive center for all my small work. I have a 1/2" step center that I rarely use.
