Mulberry- Good for turning???
Gregory Haugen
>I know of a dropped FREE tree, Mulberry. Rather large, 20" plus diameter trunk. Good or bad for turning. The tree just hit the ground this evening.
Thanks
Greg
Re: Mulberry- Good for turning???
Carole Valentine
>Sort of similar to Osage. Yellow when green, turns more brown (and hard) with age. Lots of people turn it. Be sure and end seal it as it checks and cracks easily. Probably be best to rough turn it then use DNA.
Keith Tompkins
Keith Tompkins
>Greg, What are you waiting for!!?? Grab it! great for natural- edge bowls.It moves a bit, and will turn color, but still looks good. Turns very well.
Gil Jones on Lake Seminole Georgia
>Get all you are able to use, and/or share.
It turns best green. Good-looking wood,
at least I like it.
Lan Brady
>Greg,
I have one Mulberry tree that I cut up. It had small crack worse than any other wood I've have turned. Knowing that fact, I highlighted the cracks with charcoal and CA.
I turned several simple bowls. I will not go looking for any more, but if some shows up for free, it will be turned round!
Good Luck, Lan
Bill Hale / Woodspinner
>Here are a couple of quick pics of a Mulberry hollow form.
Urithane finish, 4 years old 9 1/2 x 12 1/2 turned end grain
It was turned a little wet and checking controlled with CA.
Go for the wood !
Good turning and be safe
Bill in Dolores, CO
