Interference?
Mike Nelson
>Has anybody come up with a way to prevent the frequency of the PM3520 controller from interfering with a radio, especially AM, FM doesn't seem too bad (different frequency?). Does this happen with other lathes?
Interference?
Mike Nelson
Re: Interference?
Allen Neighbors
>Mike, my Oneway causes all sort of interference with AM/FM radio, and my shop/house intercom system.
Oneway sells an RFI Filter for their lathes. I just haven't sent for one yet. That's on my to-do list.
Someone suggested one of those little RFI filters that Radio Shack sells, but they aren't heavy-duty enough to fill the bill.
Allen
Re: Interference?
Mark Wollschlager
>Will a ferrite on the power leads have a positive effect?
Mark.
Re: Interference?
Bob Fawcett
>Seems like I read of someone using one of the Oneway units on a PM. I haven't tried it on my PM. My lathe is in my basement which is insulated with the stuff that looks like aluminum foil bubble wrap. I haven't noticed any radio interference. All my radios are in the upper floors.
Re: Interference?
Mike Nelson
>What do you mean by ferrite Mark?
Re: Interference? *LINK*
Chuck Engstrom
>You might want to contact Powermatic about this to be sure you get the most appropriate FRI filter for the controller unit they use, which may be different from the one that Oneway sells for their controllers.
If they can give you a manufacturer's part number you might be able to get it online at one of the big electronics parts suppliers such as newark.com. The Oneway instruction sheet (available at their site) shows the RFI filter on its cover with manufacturer's name and model (Corcom 10VR6). If you look this up on newark.com, you'll see that there are many variations as to lead configuration, current ratings, etc. (The 10VR6 is presently $23.74 but not in stock.)
Best--
Chuck Engstrom
Chestertown MD
Newark Electronics
Re: Interference?
robo hippy
>I have an older (6 years, with the little fan under the converter baffel, old heavy banjo) PM, and it doesn't bother the radio at all. However, the flourescent lights in the shop bother it a lot unless the antenna thing is in just the right spot. My radio is about 3 ft. from the motor.
robo hippy
Re: Interference?
Mkauder, Phenix City, AL
>I bought the Oneway version of the RF filter last year. It is pricey. I put it on my Vega. I eliminates all the noise, as long as my controller is pointing the right direction. If it faces 90 degrees to that position, it is still noisey. AM is my only real problem.
Mark
It's a long skinny animal you keep as a pet :)
Re: Interference?
HarryB
>Mike,
My DVR messes up the TV picture on the VHF channels but not the UHF channels. It does a pretty good job on AM radio stations too.
Re: Interference?
Dick Hines
>I tried to post a message that would be easy to understand but I can't get right. Go talk to a ham radio guy. He can explain it so you can understand.
Re: Interference?
Norm Smith in Nova Scotia
>Mike, I have the same problem with my PM. If you find a solution , please post it.
Norm
Re: Interference?
Mark Wollschlager
>a pole rat or something like that.
anywhooo...
A ferrite bead or core is a piece of soft iron ( and other metals) that you clip over ( or wrap around) a power cord to help eliminate radio interference.
This would help the radio or electronic device effected by interference.
The unit you would hook to the lathe might need to be more complicated.
Mark.
