CA glue question?
CA glue question?
CA glue question?
Rick in Colgate, Wi
>Last evening I used thin CA glue for the first time on a bark inclusion on an ash bowl and it got very hot and actually smoked a little, is this a normal reaction using CA glue?
Rick
Re: CA glue question?
>It will often do that especially if you wipe some up off your workbench with a paper towel. In fact it will burn your finger through the paper towel. Don't ask how I know this. The smoke you see is actually some fumes from the CA (not real smoke like from a fire). Don't let this get in your eyes, man does it hurt, again don't ask how I know this.
Usually thin CA will only do it this bad when there's a lot of moisture present.
Bill Hale / Woodspinner
>As John said look out for those fumes.
Moisture in the wood and or use of accelerator will cause the white bubbles to form. The major problem here is that if the crack or fill area is a little wide or deep the white will show after you finish.
I no longer use thin. I like the med. thin better.
Good turning and be safe
Bill in Dolores CO.
And stick to your fingers
Dave Belser
>The moisture in the paper towel causes the glue to cure fast get hot & give off the "smoke". The heat is particularly noticeable when the paper towel is stuck to the end of your finger -- Don't ask how I know this :)
BTW - the unstick stuff that they sell stings a lot if you get it on your fingers where some skin is missing, again don't ask how I know this.
Seriously now - when I use CA glue on a crack or inclusion that I'm in the process of turning I always use a face shield instead of goggles. Even if you hit the surface with accelerator there can be pockets of glue that don't dry for a surprisingly long time.
- Dave
Rick in Colgate, Wi
>Thanks! Guess I was a little surprised by the heat generated, and I know about the fumes, had to run for the shop door for some fresh air. I did not use accelerant on CA.
Rick
Ric Taylor
Re: And stick to your fingers
Ric Taylor
>Actually, it's the cellulose in paper towels that kicks the super glue into the cure mode, assuming the paper towel is dry. Cellulose is one of the substances that will trigger the instant cure of super glue. If the paper towel is damp, well the moisture and the cellulose will both trigger the CA to cure.
eaglesc
>The PH of the material you are putting it on will also have an accelerant effect.
(Too many pen tubes stuck half way in ebony.)
You said thin but there are faster setting CA's in different viscosities.Some thins are "hotter" than others.
I use it on corn cob pens( and woods for finishes and glue ups) some smoke some don't.
