Termites
Termites
Termites
Don Emmerling
>I have had some split cherry logs stored on end under an old rug for the past two months while I get around to roughing out some bowls for turning. Today I noticed very small white bugs about half the size of an ant crawling around several of the log ends. I am guessing they are termites. Is there any way I can salvage the wood for turning without inadvertently bringing those things into the house or is the wood lost?
Thanks,
Don
Re: Termites
Re: Termites
adrien
>Only termites I've seen are yellow.
Up north, the termite queen has to nest below ground. A log with no connection to the earth doesn't have a queen and shouldn't be a danger to your home.
You might check with your local county agricultural service....
Re: Termites
Re: Termites
>Moth balls or dry ice in a plastic bag has worked for other bugs. I don't know about termites.
Re: Termites
Re: Termites
tm
>i was reading this and thinking: microwave them
Re: Termites
Ric Taylor
Re: Termites
Ric Taylor
>The termites I've seen around Houston are all white.
Ric
Re: Termites
Re: Termites
Peter Hyde
>I went through a whole process of bug elimination recently with some huge fresh cut sweet cherry. This was NOT termites but Longhorn beetles and a small black beetle about the size of a pin head. I removed and destroyed all the bark and power washed each piece. When they were dry I washed them with paint thinner applied with a brush, and made sure it went into all the holes. The larvae were seen exiting in a hell of a hurry and were dead in less than a minute. I left all the pieces to dry for about a week checking for signs of activity. Anything suspicious got a shot of paint thinner from a hypodermic syringe. When I was satisfied all were dead I washed them again in paint thinner, allowed to dry and then Anchorsealed them all over. These pieces were all too big to get in the microwave and I was too busy to rough turn them down to something that would fit. I kept all the pieces isolated from any other wood until I was sure everything was dead. About a 2 week process:-((
Mug shots below L to R. Longhorn beetle larvae, frass piles 1/16" dia. , frass builder escaping paint thinner.
My camera does not have macro so images are not as sharp as they should be
Peter
Visit my site at:
http://www.oldtoolsshop.com/Galoots/pHyde/
Re: Termites
Re: Termites
Tony - Memphis
>There are pictures of termites all over the web. you can bring all the termites you want into your house, they won't hurt a thing. They die pretty quickly if they can't get back to the moist ground. They don't take heat very well either. Now, I am speaking of the subturanean (spell that?) kind. The formosan are a totally different animal, so to speak. Unfortunately, I became well educated on termites! But so far, the last treatment with that "new" stuff is working.
Tony
