We value your privacy.
>I don't currently own a lathe but would like to cut my teeth on a used one. This one is listed near me. Can I get some advice about whether this is a good deal or not? It's a Delta Model 29-3307.
>Just like the one my friend gave me to "store". I started on this lathe. I should do you fine as long as it's in decent condition. I'd grab it for $200. Check the headstock bearing and the tailstock quill travel.
You will probably want another lathe in the future depending on what you decide to turn. I wanted to do large bowls and found the 12" swing on this lathe limiting. But that wouldn't be a problem if you turn smaller stuf.
Changing the belt on the step pullys for speed change can be a little anoying. If you realy wanted to you could probably retro fit a variable speed motor to it.
Anyway, not a bad starter lathe. It's got more swing and length than a Jet mini that goes for $250.
This is a nice piece of older iron. I use a 46-460 which is very similar. Does everything I want and more. Outboard turning up to 24" is possible. If you need any help there is http://www.owwm.com/ and also http://www.acetoolrepair.com/ where you should be able to find manuals and parts lists.
Mine has a few updates like electronic variable speed.
I'm missing the legs/stand and the belt house cover for mine. I passed up a set of leges on Ebay for $50 because I'm on to my new lathe. I would be intrested in knowing more about your electonic VS adaptation. I would consider doing it to mine. Right now it's got a wimpy 1/2hp motor on it. Which is good if your just starting - catchs are a lot less dramatic and tend to stall.
>I just bought one of these that was in a lot better shape for less from a friend. I had another one that would compare to this lathe that had some bearing problems and the headstock stepped/indexed pulley was broken. It still worked like a champ. I just couldn't use the indexing features.
As long as the headstock bearings aren't shot, the motor runs well, and it's not too pitted and rusty I'd say it's worth it for a good starter lathe. You're looking at 10 1/2" diameter bowls max though. I'd replace the old v-belt with the link belts to cut down on vibration also.
>This model is, I think, a little older than the one I started out on, and that one served me well. I'd say the cast-iron stand is half the value and would still be great if you get something newer like a mini; I put a Delta 46-700 on mine and used that for several years.
My VS was on the lathe when I got it. The controller is a Leeson and the motor is a 1hp 3 phase Baldor. That's about all I can tell you. Oh and also it is really worth having!
Now the gloat bit :-) It came with a Oneway chuck with all the jaws including Jumbo, 2 toolrests, 6" and 3" faceplates,4 spur drive and a live tail stock center. Wrench, knockout and manual.New bearings have been installed. $800Can. I couldn't turn it down..... The picture was taken just after I assembled it after transportation. It's a bit dirtier now.
P.S. Aaron Gesicki has done 2 pdfs on building a stand and installing a VS system on an identical lathe. They are over 4Mb in size so I don't know if they will email. Aoron is a member here http://www.crwoodturner.com/index.shtml so you may be able to contact him
>Yup, I'd buy it in a flash if I were in your area.
Even if the bearings are worn, they can be easily replaced for roughly $40-50. This is much more massive (read: stable) than newer lathes of the same size, and heavy lathes really are better. Another good feature is that there's no gap in the bed -- many of these older Rockwell/Delta models have a short gap in the bed to allow platters up to 14", but this is usually a pain when you want to get the toolrest banjo close to a small piece, or work the back of something. New toolrests are available all over. I also find variable speed a handy feature, but in truth, I tend to rough turn at a slow speed, finish turn at a higher speed, and go a little higher still on spindle work, so changing belt positions is really no big deal -- the infinately-variable speed is a luxury, not a necessity.
>Thanks for all the advice. I went ahead and picked it up (about herniated myself...). I'm now in the lathe club. Anyone want to show me the secret handshake? Now I just have to figure out how to use it.
