VL300 Pulley Ranges
VL300 Pulley Ranges
VL300 Pulley Ranges
gtwilkins
>Good Evening All,
Finally got the walls built and the power run so its time to fire up the blue beaut. The manual I received has only 2 pulleys 10-1000/30-3000 however this one has 3, so is the middle one 20-2000?
What are the numbers on the VFD display motor rpm?
Like a kid waiting for Christmas Day,
Thanks. Trevor in Grand Forks
Re: VL300 Pulley Ranges
two ton tommy
>This the response I got from Vicmarc in December 2003
Tom,
Nominal speeds are as you quote, but they vary slightly depending on motors and drive configuration. For your information I have just measured a VL300 lathe on pre-delivery testing with a digital instrument and the speeds were 15 to 976; 32 to 2065; 46 to 3014 RPM
Have a nice weekend
Walter
----- Original Message -----
To: 'Walter Baumann'
Sent: Friday, December 12, 2003 4:40 AM
Subject: RE: VL300
Walter,
Thank you. Your response was indeed helpful. However, would it be possible to get the rpm break down for the three steps. Would it be top end 1000 rpm, 2000 rpm and 3000 rpm respectively?
Greg Jensen
>Digital read out is motor RPM.
Greg Jensen
