200+ woodworking book reviews
JET 1642 vacuum coupling wisdom sought
Pete in Holland, MI
>Guys -
The new 1642 is making chips when I get time. Been working on upgrading & building the support equipment from my old 1236 (new tool rests, weight box, face plates, chuck adaptors, etc).
Have a question for you: What ways have you been adapting the swivel vacuum coupling to the left end of the spindle? Will be making my own, so open to all suggestions. Twas thinking about using the aluminum "hand wheel" tube to simply insert a "tube" from a manufactured swivel, and hold it in place with set screws. Might even incorporate an O-ring. Or would it be better to left hand thread it and thread the fitting in? I have a metal lathe in the garage to do my own turning.
What are you doing for this feature?
Thanx.........
Pete
Re: JET 1642 vacuum coupling wisdom sought
Jerry from Lapel In.
>Contact Al Crandall at alkaron@indy.net
>Pete I don't know if the handwheel is large enough on the Jet but on my powermatic I had the handwheel bored to fit the bearing vacuum adaptor that I built. It's just a bearing with a brass barbed fitting on one side and threads on the other. I turned the threads down to be a snug fit in the bearing and epoxied it in place. The bearing then fits directly in the handwheel. I put a piece of closed cell phone in the hole to seal the vacuum. It's very easy to remove when you need the knockout bar.
Re: JET 1642 vacuum coupling wisdom sought *LINK*
John Uteck
>I made one similar to the EZ adaptors available commercially. A link showing the details is below; I wrote about it here in May 2003 (?) - you should be able to find it in the archives.
1642 vacuum setup
John Uteck
>Here's the link to the archived message.....
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=11468
Vacuum Pump Setup - Archives
