Amazing Discovery !!!!!!
Allen Neighbors
>Guess what? This morning, when I went out to the shop, my three inch face plate had magically transformed itself overnight!! It is now a Four inch face plate.!! Isn't that amazing???
Really, tho, it just so happened that Bob (at WoW) pointed out the fact that his 1640 came with a 4" plate, and not a 3". :o)
Color me embarrassed!
Allen... I feel much better now. :o))
Re: Amazing Discovery !!!!!!
Allen Neighbors
>Another discovery!! Bob was on the Oneway Forum, not WoW. Boy! Gotta get more rest....
Here's a pic of the blank, mounted.
Allen
Re: Spinning... Good!
Allen Neighbors
>Here's a shot of it spinning, RPM says 250 or so... Bottle of water shows it's pretty well steady.
Question: The pedestal says RPM X100. Is that correct?
Green Red Oak. Will turn it, start to finish; beginning about 6:AM tomorrow morning, and let it move the way it wants to when finished.
Allen
n2wood
>Allen I also have the 1640. RPM depends on the pulley you have the belt on, that is why there are two sets of numbers.
Carole Valentine
>Good thing it's green. I would hate to try to beat a hunk of dry oak that size into submission! LOL Post some pics when you finish it. My DVR would be across the street if I put an out of balance chunk that big on it!
Allen Neighbors
>I understand that, but I'm curious about the numbers. In this shot,(I'm on the slow speed pulleys) the dial is pointing halfway between the 2 and 3, and the placard says RPM X100. Is it pretty accurate, or do I have to do math to really figure it out... It's really not that important, but I'd like to know if it's really spinning at 250 RPM.
As long as it is spinning and not shaking things around, it'll be okay, but I'm curious.
Allen
Re: I'll let you know how it turns!
Allen Neighbors
Jennifer@Indy.USA
>Allen, you are having way too much fun! I love reading your posts and seeing what you're up to with that new beauty in your shop.
Keep em coming!
Jen
Re: Jen, I'm having more
Allen Neighbors
>fun than the law allows. :o) But sometimes I feel like the dumbest turner in town (really, there's only two of us). I make more stupid mistakes than I should, and sometimes I even learn from them. :o)
Thanks for posting.
Allen
Re: There is one problem with face plates.
Al Crandall (NE of Indy)
>Using a face plate to mount the rough blank means that some yahoo with a chain saw in the middle of a woods or fencerow is ultimately resopnsible for the orientation of the grain in the bottom of your work of art. Most of the time I am that yahoo, but I still prefer the lathe over the chain saw when deciding the look of my work. I start every bowl between centers so I can shift the centers to get the most pleasing orientation of grain. Production turners use faceplates or screw chucks because of their need for speed, and they aren't concerned with grain patterns. But I don't think you and I are production people. Large blanks like you are showing here are the reason I went to a two spur 2" drive center. I feel uncomfortable using a 4 spur drive in a 100 lb. blank.
2 spur drive center. *LINK*
>Al I have decided to get one of the 2 spur large drives from Bestwoodtools. I had a really nasty piece of wood the other day that just wouldn't work on my normal 4jaw drive.
http://www.bestwoodtools.com/
I know why you thought it was a 3" .....
>Faceplate. Men have been trying to convince women they have a six inch faceplate for years. After a while we lose track of the actual dimensions. You were just trying to be understated here on WC.
I used to turn on a light Delta lathe and I could count on it being right where I left it. I would put a heavy block on it and just follow it around the shop until I got the block balanced. Then I would stand in that spot and finish it, but if it was raining,I would drag it back into the shop out of the rain and finish.
Milly
>I am new to woodturning. How do you prepare your wood like in this picture. Is this already dried or is it green? do you rough turn it and then let it dry?
Re: 2 spur drive center.
Bob Fawcett
>I bought one of these shortly after the gathering. I have used on a large ugly piece of oak similar to Allen's. Works great.
Best part is you can leave your chuck on the lathe. Just open the jaws to remove.
W.C. Turner
>John,
I bought one of these 2-3 months ago. You'll love it. It should be called "Pit Bull", cause it really digs in, & holds.
W.C.
