Not sure if I ever posted this
Steven Antonucci
steve antonucci
>But it came up on the Nova Owners board.
It's my "long tool rest" for when I rotate the headstock. Black pipe construction, filed to fit the banjo by holding in a chuck and "filing". Filled with cement to reduce "singing". Capped with a turned wooden plug.
The long end is supported by a wooden "deadman" with hole in it. Pic attached in next post.
steve
P.S. I think it cost me $12 to build and a little bit of "layin' around stuff"...
Re: Not sure if I ever posted this
Steven Antonucci
Close-up
steve antonucci
Steven Antonucci
The deadman
steve antonucci
>This is pieced together from scraps, but it's basically a wooden upright with a hole in it to support the long end. Pretty darn steady for the cost.
Steve
Re: The deadman
Sean Troy
>It amazes me how you always come up with home made working tools and accessories. Great job.
bob davis
>thanks for a great idea
Allen Neighbors
>Awesome Idea, Steve. Thanks for posting it. Old Griz might end up being a bowl lathe after all. :o)
Allen
I'd be surprised...
Bob Fawcett
>if you could tear yourself away from that Oneway. I am quite sure it could do any bowl you might desire to turn.
Re: I'd be surprised...
Allen Neighbors
>That's true, Bob... I've been using Old Griz for finishing, and some bottoms.
Might be a good candidate...
Bob Fawcett
>for a buffing system. A Beall or whatever would probably fit nicely and a dedicated buffer would be a good addition.
Re: The deadman
Doug Bartos in Md
>Hi Steve,
This is a great idea. I have been putting off spending the $290 for the outrigger and this may just do the trick. Does the deadman have any type of base or is it just a couple of 2x4's with a hole to accept the end of the pipe?
Thanks,
Doug
Re: The deadman what am I missing?
Stuart Johnson
>I think I understand what the deadman but the photo shows a tree, some nailed boards and a small roof. Have I missed something?
W.C. Turner
>Me too, Stuart. But, I thought I was having an Insulin Reaction!
W.C.
Re: Bob, I made a buffing system
Allen Neighbors
>that is hard to beat. When I was recuperating from a heart attack in February, I sat in my recliner and cut out stacks of 8" discs from several different types of material: Felt, Cotton/Polyester Denim, Cotton Denim, and Flannel.
I hand stitched the stacks of material together using a large darning needle, and drilled a hole for 1/2" bolts in each stack with washers on each side, creating my buffing wheels.
I installed a grinding wheel arbor on an electric motor (1725rpm) that rotates counterclockwise. I rethreaded the arbor shaft to accept a standard thread 1/2" LongNut. This LongNut receives the buffing wheel bolts. Truly quick changes.
I use the Felt wheel with Tripoli, the Cotton/Polyester Denim with White Diamond, the plain Cotton Denim with Carnauba, and the Flannel for final buff.
The Felt wheel is two-and-a-half inches thick... the others are about 1".
I'll post some pics if you'd like.
Allen
Just wondering......
Joe Tonich - Parma, OH
>I'm tryin to figure out if this set-up would hurt ya if you had a nasty catch. I've seen solid cast rests (and a tailstock....mine....Jet 1236) that busted with a bad one....
What would keep the thin cast fitting from exploding from the stress of a bad catch?
Maybe I'm gun-shy, but I believe I'd think twice about using pipe and fittings for a rest.
Brad Vietje
YA -- Me, too !
Brad Vietje
>Steve -- the pipe rest is a great idea, but could you post a pic of the deadman actually holding the other end ? I'm having a tough time getting a sense of how it works from the photo posted ... nice Yellow Birch log, though....
Safe spinning,
Brad Vietje
Newbury, VT
Steven Antonucci
The screwed together boards is the deadman...
steve antonucci
>Not the best picture, but the deadman is simply a board with a T-base and a hole drilled in it. The hole is drilled at center height and has the long end of the pipe inserted when turning
steve
Steven Antonucci
yes- the base is an inverted T
steve antonucci
>with diagonal bracing...
The hole is drilled at center height, and just insert the pipe.
Steve
Steven Antonucci
You'd be surprised...
steve antonucci
>The pipe is "thin" vs. solid steel, but not unsturdy at all. When the lathe is running at low speed (214rpm) it is painfully slow to rough out, but the wood that needs this rig requires slow speed until round.
I turned a 23" white oak bowl that probably started closer to 25" using this. It remember weighing the log at 110# even, and it was not a problem, catches and all...
Scary is 110# spinning out of balance with the lathe at the wrong speed...
Steve
