We value your privacy.
>Just looking at the great turnings and ran across the pic of Paul Porters dye'd bowl, it is incredible, a very nice piece of work..you mentioned it was dye'd with water base fabric dye, do you mean Rite Dye?..and if so how do you mix?..I have tried the Rite dye on wood, but didn't get anything close to that color in mine...any info is appreciated...Dennis
>Dennis, this was my first try at dying a bowl. I feel real lucky that it turned out as nice as it did. I used a powdered dye called Procion� MX Dye, 028 Bright Scarlet I bought at an art supply store. I mixed about a little finger nail amount of the powder in about a 1/8 cup of water (real scientific). I used a small cheap paint brush to apply the dye. It took a couple of coats to get it even. I prepared the bowl by wetting (not soaking) the surface and sanding several times with 320 grit until the grain no longer stood up. I applied the dye, let it dry and started applying the finish.
>Paul thanks for your clear answer on this question. This is information I will file away for possible use on some of my projects. There is various methods of dying and I will add yours to what I have and intend to do. GT
>A lot of the dyes can be mixed with alcohol so raised grain is not a problem. They are ready to finish in less than an hour.The higher the % of alcohol, the quicker they dry.It seems to go on with less overlap also.
