hollow vessels
hollow vessels
hollow vessels
David Miller
>Hey guys I am new here just had a question about the contest. I have turned bowls but never a hollow vessel. Do I need a special gouge in order to do this type of work?
Re: hollow vessels
Re: hollow vessels
Greg H. from Wisconsin
>Gouge, no bowl gouges are used for the outside. The "hollowing" though is not "gouged." You need some sort of hollowing tool or tool set. John Jordan, Trent Bosch, Craft Supplies, and Packard all sell hollowing sets.
Greg
Re: hollow vessels
Re: hollow vessels
Carole Valentine
>David, I am big fan of the Kelton hollowing tools. I use them in a Hosaluk handle. Last time I checked, Lee Valley had the best prices. They come in sets of three. I use the mini, the small and the medium.
Re: hollow vessels
Re: hollow vessels
Rick Allen
>I saw Dale Nish hollow with a skew at a demo at the St Paul AAW Symposium several years ago. Greg mentioned the typical tools used for hollowing. But there are many ways to successfully hollow.
Have fun with your project.
Re: hollow vessels
You can make your own
Craig Daymon
>I know the cutters in the John Jordan tools are made from 3/16" HSS key stock. I think the Ellsworth tools use the same thing. Or you could use 3/16" HSS drill blanks.
Then, if you can drill a hole in a rod of say 3/8" diameter oil/water hardened, doesn't really matter, it won't be doing the cutting and won't need to be hardened and fit the cutter you make from the above. If you have a tap and die set, you could use a set screw like Jordan or, if not, use super glue like Ellsworth. (Others also like silver solder.)
The 3/16" cutter is a real key to success based on most of the turners I have seen demo hollowforms. It cuts well and is fairly easy to control. Some practice is needed to get a really smooth, even surface, but if you get your entry hole small enough no one will notice.
Take a look in the catalogs at the Ellsworth tools. Basically shows you everything you need to know to make the tool. (A rod with a cutting tip sticking either out the side or out the end.)
Once you have the tools, practice with some open forms so you can watch how the tool responds.
-Craig
Re: hollow vessels
Re: David, here's a couple of pics
Allen Neighbors
>of a couple of my homemade hollowing tools. I just got some round stock, and drilled a hole in the end to accept the tool bit. Drilled holes to tap out for set screws, and put them in a pipe handle. This website will explain it in pictures: http://www.aroundthewoods.com .
I bent the end on one to get inside the mouth of hollowforms. It worked until I could buy a real set. Hope this helps.
Allen
Re: hollow vessels
Allen Neighbors
Re: hollow vessels
Re: You can make your own
Jim Pugh, Elyria, OH
>Craig, if I may, I would like to correct a statement you just made:
You said the cutters were made from 3/16" keystock. Actually the cutters are made from 3/16" hss tool bits. The tool bits typically come about 3" long and a person cuts them in half to make two useable bits.
When John Jordan demoed at our club a few years ago he showed us how to make the tools. The cutters were inserted into square keystock and you could use 3/8" or 1/2".
Re: hollow vessels
Re: hollow vessels
HarryB
>Carol, How do you sharpen the Kelton tools? Do you sharpen what looks like a bevel? ...or the flat top?
Re: hollow vessels
Re: hollow vessels
Carole Valentine
>Always sharpen the bevel. I just use a diamond card. The Keltons have a thin layer of some kind of special metal on the flat top surface. If you sharpen that surface you will destroy that layer.
Re: hollow vessels
Leo Van Der Loo
Re: hollow vessels *LINK*
Leo Van Der Loo
>Hi David
A bowl is also a hollow turning, but the hollow forms with small openings are made with more specialized tools, Darrell Feltmate has a very good website with a lot of info for making tools and jigs etc., also has some short videos you can watch on how he uses the tools, very helpfull, a good e-mail address to bookmark and visit.
Have fun and take care
Leo Van Der Loo
http://aroundthewoods.com/hollow1.shtml
