Replacement Bearings: different levels of quality?
Devon Palmer
>All,
I recently traded off my jet mini for a Rikon mini lathe (12' swing, indexing, 4 inches more between centers). I'd give it a 5-6 in the quality range, good enough for a second lathe for demo's and stuff like that. I've had to replace/upgrade a few things already and the bearings are not long for this world (run warm, slight chatter, etc).
Are there any REAL different quality levels in bearings? I'd want to go with the highest reasonable quality and am not sure what to ask for. Previous experience would tell me to just go for a matching timken set and call it good.
- Devon Palmer, Columbus Ohio
Re: Replacement Bearings: different levels of quality?
Keith Tompkins
Keith Tompkins
>Hi Devon,absolutely, there is a difference. The type of steel used, the sized of the rollers or balls, quantity of rollers, etc. all play a part. For example, when I restored an old Schwinn tandem bicycle, I discovered fifty-two 1/4" balls in the rear hub assembly! That's heavy duty!
>I agree with Keith. When I built a lathe from an old lathe carcass I described what I was doing to my local bearing supply house. We went through the catalog and ordered a special bearing that would handle stress in both direction, rotary and side to side. I was also able to put a double wide bearing so that it supported the shaft better. That was 10 years ago and my friend who bought it from me is still using it.
Don Evans
>Devon:
What the others said is true, however you can still go overboard with it also. Price may dictate what you get. Timken is a good brand and so is Fafnir.
No matter what quality range you decide to go with make sure you install double SEALED bearings, NOT double shielded. The sealed bearings will not only keep the sawdust out but it also keeps the lubricant in making the bearings last much longer.
How do you tell sealed from shielded, the sealed bearings will have a black material (firm but you can dent it with finger nail) on the side of them, covering the balls or race. The shielded bearing will have a silver metal on the side of them.
Don
Eric in Los Gato, CA
>Devon,
The simple way to understand relative bearing quality in type/size is by the class of the bearing. Higher is better. I haven't spec'd a bearing for a number of years but based on what I remember I would go for no less than a class 4. If there isn't much of a price premium I would go higher. Now that I'm thinking about it I wonder what the manufacturers use.
Good luck,
Eric
