Light for inside turning
Norm Smith in Nova Scotia
>It is interesting that there is a lot of discussion below regarding using a light inside a turning so that the piece can be turned thin on the outside. I was looking through a new The Source (Radio Shack) flier and came across the following. High powered LED reading lamp with a Flexible gooseneck which allows you to adjust the lamp. #6118968. Price $24.99 Canadian. In the photo there looks to be a clamy on the end. Would this do the trick?
Norm
Re: Light for inside turning
Allen Neighbors
>Norm, you said a "clamy on the end."... did you mean clamp?
I'm interested in this technique, and would like to check out this lamp you're describing at Radio Shack. I wonder how hard it would be to attach it to a Morse taper...
Thanks for the info.
Allen
Yes Allen, Should read clamp.
Re: Light for outside turning
Mike Brazeau
>You can turn a Morse taper on any block of wood between centres to fasten the light to. I saw Stewart's demo at Louisville and am familiar with the new LED type lights. I have a number of the 6 or 8 LED flashlights. I am not convinced that they would give the same effect of illuminating the whole interior to give an even transluancy as they are more directional whereas a candelabra bulb will be emitting all around itself.
My wife has a bunch of AC operated candlesticks intended for putting on window sills. They take a candelabra type bulb and would be easy to adapt. Probably a lighting store could supply you with a candelabra socket that could be fasten to a piece of dowel or any turned stick for that matter with Morse taper turned on one end. I don't see any huge risk, but I am familiar with wiring protocols etc.
As was stated in an earlier post this is entirely different than hollowing and using a 12 V taillight bulb on the tool or fibre optic for ilumination. I think the new white LED lights would be OK for that if you could find them just mounted on the end of a cable or something that is small and flexible.
Mike
Using a light inside for outside turning?
OB O'Brien
>It appears this thread addresses putting a light inside a vessel and then turning the outside to an even color or translucense. OK fine, but what if the inside has ridges and uneven areas. If that's so and then you turn the outside to even color, you will follow all the unevenness of the inside. I hollow the inside of a lot of ultra thin vessels with the help of a laser shining on the outside. I think Frank Sudol uses a 12 volt tail light on the inside and hollows the inside in the dark. Others do the same with some sort of low voltage light from the inside. I have a surplus dental fiber optic rig with a 350 watt light source. I run the fiber optic cable down the boring bar and splay the fibers to creatr a bright horizontal line from the inside. This works fine and is really neat, but I have found it's not necessary if you use the laser properly. After the outside is shaped, I turn mine down to an even 3/23 wall thickness or less using the laser and hollowing from the inside. I don't think putting a light inside to shape the outside is worthwhile. Just my two cents worth. OB
Brad Vietje
Re: Using a light inside for outside turning?
Brad Vietje
>I don't have the technical answer that was sought in the original post, but wanted to respond to OB here -- I've seen Stuart Mortimer do this twice now, and its a pretty slick technique. As a hollow form turner myself, (both by hand and occasionally with laser-guided boring bar) I understand what OB is getting at, but Stuart Mortimer goes much thinner than 3/32" -- more like 1/32 - 1/16. This is a technique for making a real show-off piece, or a hollow ornament with very little weight. It could also be used, and presumably would be, by those that don't have a stabilized boring bar set-up with laser guidance, and would work well on light colored woods to get in the 1/8" - 3/32" range. Going really thin probably isn't very useful for free-stranding pieces to display/sell in a gallery, as breakage would be a problem.
Safe spinning,
Brad Vietje
Newbury, VT
Bob Elliott
>I saw Stuart demo this technique in Utah a few years ago. The form he turned was more like an open vase. There were no ridges on the inside of that turning!
Al Crandall (NE of Indy)
>I saw Stewart's demo at L'ville. In addition to leaving no ridges inside a hollow form while using only hand held hollowing tools, he managed to completely finish all hollowing of the piece through a small hole without stopping the lathe to clean out the chips. I would have thought this feat to be impossible but I saw it with my own eyes. Anyone who can make all the chips self eject through that small hole can turn the inside smooth enough to use as a form to copy for the final outside shape. I am certainly not in that league.
Lan Brady
>Al,
No plastic spoon?
Lan
Re: Plastic spoon chip ejector, second generation.
>Hi Lan. The first time I got caught demoing without compressed air, I was forced to scrape out the chips with a 12" flexible machinist's scale (ruler to woodworkers). The plastic spoon is second generation upgrade tooling. Third iteration will probably be a plastic ice tea spoon duct taped to a wood dowel. Think I can market it?
don in central IL
>I'll buy one, if the price is right.
Re: Put it on E-Bay
Russ Fairfield
>No telling what price you will get for it.
Re: So, how much would I have to pay you, Don?
Re: Put it on E-Bay
Bill Hale / Woodspinner
>Small wooden kitchen salad or cooking spoon. BEEN DOING IT FOR YEARS.
Bill
eliot
>It never occurred to me that getting the chips out without air or whatever was a particular sign of skill. It seems to be more of a magic trick. What's the point of it? (I suppose the turning would go faster.) I've seen a few master hollow turners in person and on videos stop frequently to get the chips out. They don't seem to consider it anything more than a housekeeping necessity. When I hollow turn, I use air to clean things out so that the tool doesn't get all clogged up in there.
Bob Elliott
>Here is a picture from the 2003 Utah Symposium disk with his light in place & a turning in progress.
