Super Nova Chuck / Power Jaw Question
Wilford Bickel
>I picked up a used SuperNova Chuck with power jaws this past week. This chuck looked like it had never been used and I have discovered why! The chuck and insert are great but when I put the jaws on the runout was awful. I started hunting the cause and found out that on 2 of the jaws the curved bar on the bottom side is not sitting down in the curved slot on the jaw slide. My other set of power jaws and the regular jaws for my SuperNova2 chuck fit fine. I know that Teknatool says to use a block of wood and knock the jaws in initially if they bind but this is set is refusing to seat even with a light knock. (I don't want to beat it to death!!) As I have nothing to loose if these jaws don't work (I wanted the base chuck and the price was right!) what would happen if I took my dremel tool and a small grinding wheel and relieved the curved bar enough to allow it to sit down into the groove.
Any thoughts or ideas??
Thanks
Re: Super Nova Chuck / Power Jaw Question
Been there, done that...
Peter Teubel
>...but try a small file on edge instead of a rotary tool. More control, less metal removal.
Re: Grinding the curved
Allen Neighbors
>seating bar would probably be alright, as long as you grind off the right spot. If you grind off the wrong area, it will seat off kilter and never get aligned.
When you do grind it down to fit, if you follow the suggested procedure for tightening the jaws... i.e., afix the jaws loosely, close them loosely, then tighten the attachment screws... they should work alright.
Just my thoughts on it.
Allen
Thanks
Wilford Bickel
>Thanks Peter , Allen
I won't have to clean up anything but the center edge of the bar, so it should still line up fine. As long as I clean up a little extra on each side of the slide it should be able to line up fine with proper screw adjustment. We are probably talking a few thousands to make it pop into place.
