Paper Joint
Paper Joint
Paper Joint
eliot
>Suppose you have a glue up with numerous paper joints in it (so you can split it apart easily later in numerous places.) Now suppose you have changed your mind because you no longer want to split it apart, you want to turn it thin, and you are afraid that it may fly apart -- but you like what you have so far and don't want to throw it away. How would you treat the piece to "un-do" the weakening that's there because of the paper joints? I have thought of soaking in some kind of hardener or whatever, but I have no idea how thin card stock( the paper) will respond.Any ideas?
Re: Paper Joint
Re: Paper Joint
>Eliot I haven't tried this but I think thin CA might work. You would be soaking the paper hopefully. The best bet would be to break it apart and glue it back together with something that will last like yellow glue, epoxy etc. The paper joint works because you don't use enough glue to completely soak the paper. That's why I think thin CA might work. Try a test. glue a couple piece of wood together in the same way you did the joint. Then soak it with thin CA and try to break it apart.
Re: Paper Joint
Re: Paper Joint
eliot
>John,
Thanks; I'll do the test with thin CA glue on some scrap. It's not really practicable to break apart the joints and re-glue, because there are about 50 joints. What I did was to glue up about twenty five 3/16 inch thick slabs of 6x7 inch Home Depot cedar closet liner with sheets of colored card stock between the thin slabs.(I'm afraid the crazy thing looks like a barber pole.) As I think about your suggestion, if the test seems to work, I think I'll go ahead and turn the piece to about 3/4 inch thickness as it is ( that probably won't fly apart) and then try the thin CA glue treatment on the 3/4 inch thick result. (There's no way the thin CA glue will soak through the full thickness of the piece.) Thanks again for your help.
I must say that you seem to be extremely active on this site and are always willing to help out when you can. So thanks again.
Eliot
Re: Paper Joint
Re: Paper Joint
>Eliot During the summer my photo shoots are hit and miss all day long and so it the processing etc. There's almost always 15 or 20 minutes between shoots so I have time to play. That won't be the case in about 2 more weeks when school starts back. Then it's run run run all day long and often into the evenings and weekends.
Re: Paper Joint
Keith Tompkins
Re: Paper Joint
Keith Tompkins
>Hi Eliot, two things to consider...one, the paper joints will show, especially when the finish is applied. When the paper joint is exposed at anything other than a 90 degree angle, the joint will appear very wide, and not too attractive. Maybe just use the glued up piece as a test or learning experience.
Re: Paper Joint
Re: Paper Joint
eaglesc
>I do a lot of laminating when I make my pen blanks and have tried using paper to simulate glue lines accents ets.
I use CA almost excllusively and have not had 100% success using paper.
My theory is the CA sets before it has the chance to be absorbed by the paper.
That being said I have had success making a pen entirely out of newspaper but failed with graph paper,
Construction paper in colors seemed to me to be similar to newsprint it it did not stay together.
I have tried putting paper in an acetone pleximix to stabiize it prior to using CA with no luck.
With the inertia of a piece the size of a bowl I would wear a football helmet.
Good luck.
BTW I still experiment with the paper.
Re: Paper Joint
Re: Paper Joint
eliot
>Keith,
Actually I have FOUR pieces of paper at each junction.And I have used different colors so that it would indeed show. That was the idea. But you're right: they are very wide especially when cut at an angle. The whole thing looks like a barber pole! My wife also suggests that I drop the experiment. I may do just that. Then again, like some turners, I hate to waste wood ( in this case effort). I may press on and see if I can't salvage it somehow. I don't believe in working on something that will be marginal, at best. I would have to come up with a good idea to get something worthwhile out of it.
Re: Paper Joint
Re: Paper Joint
eliot
>eaglesc,
You appear to be a true experimentalist! I admire it. I may well have gotten in over my head on this one. I'm going to give it some more thought and perhaps try a few things before giving up . What do you think of that Minwax hardener (or other wood hardeners) as a possibility?
I do kinda wear a helmut when turning risky stuff. It's a Triton Power Respirator. I've been wearing it when turning ever since I got wacked while power sanding another paper joint glue-up. Got two bruises --one on the chest and one on the chin. It''s really unbelievable how fast it all happens! And it was while sanding -- not a catch . I was turning too fast and pressing too hard with the power sander. So there was too much heat, and that melted the glue. Really stupid!
Anyway thanks for the warning.
Re: Paper Joint
Re: Paper Joint
eaglesc
>"eaglesc,
You appear to be a true experimentalist! I admire it. I may well have gotten in over my head on this one. I'm going to give it some more thought and perhaps try a few things before giving up . What do you think of that Minwax hardener (or other wood hardeners) as a possibility? "
I got into vacuum stabilizing 2 years ago when I started making corn cob pens. My first attempts were with Bondo wood stabilizer.Once I opened the can I realixed it must have beeen something like acetone and plexiglass or some other type of plastic dissolved in it.
At the cost of the pre made stuff I went with the home brew acetone plexi.
I have never tried the mini wax stuff, it may be different but the amount I use and the cost of making my own is no comparison.
I am not sure how much paper you are using.I have had luck using one thickness between 2 pieces of wood but multiple layers of paper has been whewer I get blow out.
ALso consider what type of dye is being used on the paper.I normally wipe the paper I am using with acetone and a paper towel to see if I get a color transfer.Most of the papers I have tried don't transfer the color.
What I came up with is if turners use a paper joint intentionally because it is a weaker joint then I may be headed in the wrong direction.That's just my take but it hasn't stopped me from experimenting.
good luck.
Re: Paper Joint
Re: Paper Joint
>On the few times when I've needed a colored seperation line I have used colored epoxy. I color it with india ink or powedered chalk or paints. If I want a specific thickness I glue a small piece of wood in the scrap area. An example would be some hand mirrors I made years ago with colored lines. I cut a toothpick down to the thickness I wanted and CA glued it to the outer area of the wood. Then I mixed up the epoxy covered the wood and clamped it together. I haven't tried multiple layers yet however.
