off center turning safety
>Here's a safety tip. When turning off center work use a tool rest that is as long as the piece even if you are only going to turn a small section. The long tool rest keeps you from hitting the turning with your hand when you reach to turn the lathe off or change speeds. It's still pretty scary.
Re: off center turning safety
Re:Well duh!! Why are you ........
Jamie Donaldson
>. ....swinging perpendicular rather than parallel to bed? Was this piece mounted just to show example?
>Dang I knew I was doing someting wrong. I wondered what that tailstock thingy was for.
John, what's that gonna be?
Carole Valentine
Re: John, what's that gonna be?
>Carole I'm working on a flower based on an inside out platter. It's not working as well as I wanted. It's one of those pieces that you have to try to see how the techiques work and then you can improve on it. this is the center spindle that is turned on 3 axis and then carved. The flower stem is also turned on 3 axis and carved. Haven't decied on the base het other than it will start as a geometric shape.
