Rockler Bandsaw Table?
Carole Valentine
>Anyone use this? Is it worth it? There is a pretty good deal going on them. My saw table is not very big and I hate my fence.
Re: Rockler Bandsaw Table?
Allen Neighbors
>Never used a Rockler, but I advise you to check out the IncraJig TS III system for table saw/router precision... before you make a final decision. It's accurate to 1/1000th of an inch... repeatable. I had one for years, and it was absolutely flawless!
JMHO.
Allen
Carole Valentine
>Afraid the Incra is out of my price range. :( I could make a table, but I would rather be turning. $139 on sale for $79 seemed like a good deal for a 24" table with fence. Still thinking about it. Is it reduced so much because something is not good about it, I wonder?
Ron in Drums PA
>If I remember correctly, you have the skills to build one yourself. I think you would be better off.
Allen Neighbors
>If it's reduced that much, they must be planning a newer model, and trying to clear out present stock. My guess.
I understand the financial aspects of it. I sold my IncraTSIII system for half what it cost me, just prior to receiving my new lathe, wish I had known you needed it.
Bob Fawcett
>I was gonna recommend the one from Woodpecker since the table material is much better in my opinion. Now I look on the web and see they don't have one listed. You still may want to look at the drill press table.
They used to sell sheets of the material. Its called Finform. I bought some once and used it to build an extension table for my table saw. Great stuff. If you decide to build your own, call them, they still may have some. Its 3/4 birch plywood with a phenolic coating on the top and bottom.
www.woodpeck.com
Stuart Johnson
>Carole, I've looked at it several times. It was a fight but I decided to pass not because I don't think it is good but because it sounds like I would need to make some modifications so it would fit. I do believe it is a good buy at this price.
Just did a Google and found this *LINK*
Ron in Drums PA
>It's for a circle cutting jig, but this person is cutting 2" thick stock.
For flat work all you would need to do is clamp down a board for a fence and you are set.
bandsaw table
Phil Powell
>For the price you can't go wrong. I've met Mark Duginske, he demoed the system
at our turners meeting. He made it look like a needed accessory. I'm buying one!
The table on my band saw is just too small and if for no other reason I want one.
Peter Hyde
>Carole I just checked this out and I think if you are wanting it just for cutting circles then it is not a good buy. I noticed the top is 11/8" thick which will reduce the max thickness you can cut by the same amount. That's a lot. Bandsaw fences are not something you really need. I re-saw just using a piece of wood clamped to the table with no problems. Circle jigs are really easy to make but they must allow the piece to be fed into the blade before it is turning in the jig. This one makes you feed the piece in from the side of the blade as the wood is turned. Not a good idea and although it might work it is asking for broken blades. If circle cutting is what you want email me at chirperchippy@yahoo.ca and I will send you some drawings. All you need is some 1/2" plywood to make a good jig.
