leveling a lathe.
leveling a lathe.
leveling a lathe.
>I think my lathe has more vibration than it should. I have a powermatic 3520 with $300 lbs of rock under it. It does pretty well but sometimes I feel like I should be able to run a fairly small piece at higher RPM and not get that little vibration. I know the wood can be out of balance just because of the nature of the beast but i would like to keep the vibration to a minumum.
Here's my question. I you just crank the feet down until the machine doesn't wobble is that enough? Would it be better to level it in both planes? I know my floor isn't perfectly level or flat. I've heard machinist's talk about this and wonder if it not only would it keep the lathe running true but might reduce vibration.
Re: leveling a lathe.
Russell L. Babbitt Jr.
>I leveled mine but also tried to make sure that each leg has about equal weight on each leg. Just by feel on the leg adjusters.
Brian Hahn in SW Wisconsin
>I go for a "firm" footing more than level. That is, each foot firmly pressed against the floor and carrying the correct proportion of the load. Usually I judge the load by how hard it is to turn the foot adjustment screws/bolts. Sometimes I also try to lift the leg to judge the load, using a piece of wood or a small pry bar for the heavier tools.
With the lathes, I generally adjust the headstock end for level, then adjust the tailstock end for a level bed. Then I tweak the tailstock end to get an equal load on each foot. It really seems to help. As a matter of fact, I usually do it when the lathe is moving more than I think it should and it invariably solves the problem.
I do this with all my stationary power tools, not just the lathes. Once a tool has been adjusted, it usually doesn't need to be tweaked again until it is moved (or walks to a new location on its own).
Jennifer@Indy.USA
>Hey John,
I put a couple of roofing shingles under the feet of mine and they gradually sunk in and leveled it out and smoothed things right out. I got them from Lowes for nothing. They were in a torn open bundle that had damaged ones in it. They just gave them to me.
Jen
>I got some scrap rubber stuff from the machinery dept. at work (sort of like shingles) and did something like what Jenn did.
>That's interesting. I would think rubber would add to the vibration. It might isolate if from the floor but wouldn't it let the machine rock? I want it to be solid. I would bolt it to the floor but I do need to move it from time to time. I still do a flat project or two when necessary and during those time I need to move the lathe out of the middle of it's space. I can see how the shingles might work they are not springy but probably act as a sort of free forming space filler.
Leo Van Der Loo
Leo Van Der Loo
>Hi John
If you had a metal turning lathe you would have to get your lathe setup without a twist in it, not necessary when you use your tools freeform.
Having a kind of equal load on each leg helps for the lathe sitting stable, but most wood lathes are not so rigid that the legs not adjust themselves some, but sitting on concrete the legs behave somewhat like leather soles on a waxed dans floor, and so using some roof shingles wood help prevent that somewhat, however I would bold the lathe to the floor, even if you have to move the lathe sometimes, you can get anchor bolds that have the nut part in the concrete, and so you can take out the bolds and move your lathe and there is nothing sticking up out of the floor, and some air would blow out the holes if they where filled with sawdust etc.
Just My way of looking at it.
Have fun and take care
Leo Van Der Loo
>Leo I was thinking about your bolting idea last night when I decided I needed to move the lathe. I'm going to move it this afternoon and see if I like that position. If it works out I'll try bolting it. I can always remove the bolts if I don't like it.
Keith Newton
>Hey Jon, I am puzzling over that $300 lb. rock. If you are thinking of adding more, I have some rocks that I would like to sell you at that price. Ha
When I was fighting this problem with my old powermatic #45, then 90, they had sheet-metal stands, with bolt holes through bent out tabs about 6" apart on each end which was a joke.
What I ended up doing was to bolt on a big thick steel plate that I bought from the scrap metal yard to the outside of each leg. With this I widened the stance, and stiffened the ends on the axis perpendicular to the rotation. I started by just doing the headstock end, which helped, but when I was working outboard, I could see the other end wagging like a dogs tail, and of course the tail also wags the dog, so I added a big plate on that end, which got rid of an awful lot of it.
After that, there was still some flex in the top of the stand where it is bolted to the base, and you may be getting some there in yours as well. I will email you some photos
>Keith I turn some off center pieces and that creates a lot of vibration in itself. that's why I put the rock under there. In fact I just found some military sandbags that I bought so I'm going to replace the plastic bags the gravel came in that leak anyway with the new military bags. Hey then I could paint my lathe camo and put a rifle rack on it and I would fit right in around here.
I have a friend who used to turn hollow burls off center. He had to run them at high rpm to get clean cuts when cutting "air". He added 4" angle iron extensions to the legs. They stuck out 3 feet on each side. He cut the top off the side that he walked over all the time to keep from tripping over it. I would probably still trip over the other 3. It was amazing how steady his lathe was after this. It was one of the first 3520 powermatics. At that time I was amazed a machine that heavy would move but now I'm having the same problem with offcenter pieces.
Bob Fawcett
>I have a Powermatic 3520B. I leveled mine when I set it up. I do this with all my "stationary" tools. I just use my carpenters level along the bed then across the bed. It usually takes 2 or 3 iterations to get it to acceptable level. I have turned a few larger pieces of wood that started out of balance, and vibration is minimal.
I thought about bolting it to the floor, but haven't tried yet. If you used a stud anchor, you could still level the lathe as well.
You could also drill a second hole in the leg and use the leveler feet as well as a concrete anchor.
gtwilkins
>John, for the Vicmarc it recommends using rubber for a vibration damper when you bolt it to the floor so I managed to get some conveyer belt from the mill and used it, so I have rubber all around the lathe to stand on. (My mate bought gym matts, I'm now broke).
I was moving around to get best light and I used Tapcons to hold it down temporarily and I am not so sure but they might be strong enough alone as I have the weight on the adjusters, opinions anyone?
Jim Shewan
>I recently aquired a second hand VB36 which I dyna-bolted to my rather uneven concrete floor. I leveled it with old roofing lead under cork tiles. The installation instuctions advise against overtightening the floor bolts as this is often the cause of mysterious vibrations.
The lathe runs sweetly and I had no trouble turning the green oak in the photo.
Steve Mushinski
>Level in all directions. If you have it level both ways then you will have even weight distribution. I feel it is very important for all machines for accuracy. My floor is well over an inch out over 4ft and my lathe doesn't vibrate unless it has a unbalance load. Then I would expect it too do just that. - Steve
Allen Neighbors
>Jim, your pic won't load all the way for me. Cuts off just below the upper red hook. Is that my computer? or the pic?
Allen
George Van
>Allen,I have the same problem.
Jim Shewan
>Oops, cut the wrong bit off.
Jim Shewan
>Sorry Allen, I cut the picture down to send it easier and sent the cut off bit.
