Best way to fill a crack with turquiose?
Ken Langenberger
>Do you fill the crack with dry turquiose and then put CA or expoxey on top of it? What is the better choice CA or epoxey?
Thanks
Re: Best way to fill a crack with turquiose?
Re: Best way to fill a crack with turquiose? *LINK*
Gil Jones on Lake Seminole Georgia
>I do not know the better choice. CA is faster if you are able to tolerate the fumes, and epoxy is easyer on your lungs, but takes more time. I crush the Turquoise, fill the cracks/voids, wet the filler with thin CA. Repeat that procedure if needed to have the filling material slightly above the wood surface, then power sand the filler back down level. It seems to work okay for me.
Black Cherry Bowl w/ Turquoise
Bill Hale / Woodspinner
>Ken
I do a lot of it. Finish sand and spray on a coat of sanding sealer. The sanding sealer will help prevent the CA from darkening the close wood. If the crack is large I do a base fill with dark or black sawdust and CA. Crush the turquoise fill the crack to just the top, do not pile up it's a waste. I do thin first to set and then finish with Med. You may need to apply a little more CA to top out. Now power sand smoothe to about 600 grit Finish the wirk as you normally do.
DO NOT TRY TO CUT THE TURQUOISE WITH YOUR TURNING TOOLS.
Good turning and be safe
Bill in Dolores, CO.
Wally Dickerman in Arizona
>Turners here in Az. use turquoise a lot, since this is where a lot of it comes from. You can buy it crushed or you can crush it yourself. I along with many others prefer to use epoxy. I mix the turquoise and epoxy into a paste and apply it into the cracks and voids. Get some blue glitter from a craft store. Add just a little to give the turquoise some sparkle. The next day I grind off the excess down to the wood using a drill and 80 or 100 grit discs. I finish it off with 240 grit then finish sanding the piece in the regular way with the finer grits. Turquoise is stone, so turning tools won't touch it.
Wally
Where do you get turquiose?
Jim K in Trappe PA
>Thanks,
Jim
Re: Where do you get turquiose?
Gary Evans Tallassee, TN
>Hey Jim,
There is at least one guy in AZ who will sell you crushed turquoise. If you can't find it any other way, I may be able to find his e-mail for you. Try Googling on crushed turquoise.
Gary
Re: Gil, that black cherry bowl
Allen Neighbors
>has a reversed, and upside down, Texas on the right end. :o)
Looks Good!! The bowl, I mean. :o)
Allen
Re: Hey, Wally,
Allen Neighbors
>try to find some tool bits that are harder than M2 steel. I'd try M4 or better. I use some of my Dad's leftover 1/4 x 1/4 x 1-1/2 tool bits in my Oland Tool, and it cuts the turquoise. I don't know what the steel is, but it takes light cuts, high speed. Dulls about like a bowl-gouge-on-pecancrete fast, but still cuts the high spots down. But like you say, my M2 bits won't cut it, at all.
Allen
Allen Neighbors
>I also buy from a guy in Arizona. 1/2 lb bag for 5 or 6 bucks... raw turquoise... not polished. I crush it with a plate of steel in a box of steel with a shortened railroad spike handle. I'll try to get a pic of it tomorrow or the next day to post, if you want to see it.
Allen
>We're lucky around here. One of the largest gem shows anywhere takes place in Tucson every winter. Bulk turquoise in less-than-gemstone quality is available.
Craft Supplies sells turquoise that's already crushed.
Wally
Re: Best way to fill a crack with anything
Russ Fairfield
>We love our CA because it is fast, but that doesn't mean that it is the best thing to use. Sometimes what we do because it is faster is not the best thing to do.
It will take about 10 years to learn whether CA or Epoxy was the better choice. That will give the CA a chance to turn orange with age and exposure to UV, to shrink and pull away from the wood, and in the worst case fall out of its hole if you live in a dry climate. Sometimes we can get lucky, but the risk is always there.
If you had used a cheap epoxy, it might yellow with age if it was in a humid climate for those same 10-years, and it might have shrunk if it wasn't, but it will have remained elastic enough that it didn't come loose.
A good epoxy will not shrink or turn orange with age.
