Lathe saddles
Lathe saddles
Lathe saddles
TDaniel
>There appears to be a market for "lathes saddles". Seeing the "Boss" sitting astride the big blue in a thread below makes me wonder why someone isn't jumping on this market. I can see silver medallions, rawhide loops, leather fringe, choice of colors, ...there is no limit. Are the Chinese looking at this? :)
TD
Re: Lathe saddles
Re: Lathe saddles
Bart Leetch
>The saddle for the Jet & other mini lathes would have to be pretty small not to mention the small rider to use it.
Re: Lathe saddles
Re: Lathe saddles
Jennifer@Indy.USA
>TD, I got a good chuckle out of your post. Since I have a non pivoting headstock on my lathe, I'm always fighting the problem of bending, twisting and leaning over in order to hollow. In my class this summer Graeme suggested to me to devise something so that I could sit on the bed of the lathe and hollow. Then after seeing Ellis and his efforts to work around the non pivoting headstock, I decided yesterday to give it a try. I used a 1"thick pad that I had laying around and a couple of towels folded over...a few turning blocks stacked up for a step and on I hopped. Giddy-up! ....but all too soon I realized that now I was hunched over forward! The vessel was too low now, or something? It wasn't working.
Back to the drawing board. :(
Jen
Re: Lathe saddles
Re: Lathe saddles
Jim Swank
>Being a lady and all, you should have been riding side-saddle.... :)
Re: Lathe saddles
Re: Lathe saddles
Jennifer@Indy.USA
>Jim, you're probably right... considering I do my turning in a skirt and heels! HA!!
Re: Lathe saddles
Funny!
TDaniel
Re: Lathe saddles
Re: Lathe saddles
>There are some lathes out there (JET 1442 and 1642, Powermatic 3520 come immediately to mind) that don't need a saddle. They have the capability to slide the headstock as well as the toolrest and tailstock along the bedways. With these, you can work right around the end of the lathe without climbing on top. Just remove the tailstock, slide the tool rest all the way to the right end, and move the headstock as far to the right as is needed by your hollowing tool.
Wouldn't you know it, to take advantage of this capability, I'm having to move about 2/3 of the tools in my shop, and some lighting and other electrical connections, just so I have the room to work around the end of my new 1642. When I'm done, do you think there's any chance I will find out I don't even like doing hollow forms?
Re: Lathe saddles
Re: Lathe saddles
Bill Grumbine (Kutztown PA)
>William, the Poolewood has that capability as well. In fact, I am seriously considering moving the headstock down to the other end of the bed, swapping it with the tailstock so that I am turning on the other side. It is not a problem when I am alone in the shop, but if I have two students on the Poolewood and the Vega, they are going to be cheek to cheek, and I don't mean the ones on their face! :0
I did talk Ellis into using my captured hollowing rig for a while, but I think he did not want to use it for fear of getting to like it.
Bill
Re: Lathe saddles
Re: Lathe saddles
>William I'm still playing with the location of my lathe. Seems no matter where I move it I run into some technique that has me moving and either the wall, the tool box or the bandsaw is in the way. Then I move it out so it clears those things and now it's in the way of other things in the shop. I need a bigger shop. I'm sure you've never heard that before. I do like being able to turn off the end. Instead of sitting on the lathe be you could put a tractor seat on the end. Beats a saddle.
Re: Lathe saddles
Re: Lathe saddles
Allen Neighbors
>That's really good! (Grin 'n Haw, here) But really, He's just trying to get into his work... but he still doesn't have the opening large enough. :o) TD, the saddles would have to be made out of rough-out leather so you could hang on without using reins.
Jen, I solved the bending and stooping over problem by raising my headstock center to 49" above the floor. I now have to stoop over less, and can sand while sitting on a bar stool. My old Griz was at 46" (If I remember right) and I haven't had back or shoulder problems since I set this new lathe up this high.
... Got some old saddles I'd like to sell... I've shortened the stirrups and trimmed the pommel and horn.. (just joking).
Allen
