what to do with Box elder
Bob R
>A guy just dropped over a big Box Elder burl. What should I do with it so it it is turnable. I don't have a lot of room to store it. I green and wet and starting to split.??????HELP>
Re: what to do with Box elder
Gary Evans Tallassee, TN
>I would go ahead and cut it into blanks and coat with sealer on all surfaces. Square blanks are somewhat easier to store. If you still don't have room for it all, I'll send you my address. 8^]
Gary
Ric Taylor
Ric Taylor
>It's not worth the hassle. I'll get rid of it for you.
Ric
Bill Hale / woodspinner
>DANGER DANGER DANGER
DO NOT PUT THIS IN YOUR SHOP! TOTAL CONTAMINATION POSSIBLE!
Ship to me for disposal.
Bill
merv Graham
>Definitely not turnable send it to me for disposal {;o))> No it is great stuff has remarkable colour and grain. Hack of a big hunk and go for it. Make us all jealous
Brad Vietje
Brad Vietje
>As usual, I agree with Gary. But if you are ready to turn it now, you DON'T need to dry this before you turn it. I'd cut it into the sizes you can handle, and wax all cut surfaces -- keep it out of sun and wind. Boxelder Burl is quite stable, BTW.
I turn a lot of it green to final dimensions, and even wet sand to about 320, then dry it in a paper bag. Once dry, I either hand sand very lightly with 400 to remove the fuzzy texture, or lightly with a fine (gray) ScotchBright pad to smooth without destroying the rippled texture that develops.
For really smooth, non-textured results, turn it twice (having left thick walls the first time), and sand as usual when dry -- just remember that it is not a very strong wood, so real thin walls will not have much strength for the finish turning.
Safe spinning,
Brad Vietje
Newbury by way of Springfield, VT
www.stellafane.com
