Filling small crevices all through the wood
eliot
>Let's say you have a block of wood that is inherently filled with small voids about the size of large ants. You like the wood, but you want the surface smooth. You can't sand them out because more appear. I've tried mixing up sawdust with dilute glue and wiping that on. Also tried the same thing with with sanding sealer. Both methods worked to some extent, but voids remained. Any thoughts?
Re: Filling small crevices all through the wood
GaryG in MD
>Eliot,
You're not going to like this answer, but I have a two parter for you.
1) In this piece of wood, celebrate the voids; it is what it is. You'll never hide them, even if you fill them and make the surface smooth. So why bother? Take it even farther: sand blast it or rough it up with a wire brush. Go with the texture thing. You could even hit it with a torch and crisp up the edges a bit. You can never have too much "character".
2) To make yourself happy, get another piece of that same kind of wood -- only without the holes.
I'll want to see it at a future meeting. ...Gary
merv Graham
>Ditto on that I even look for wood that I can enhance. I use epoxy glue with coloured powders from Michael's craft store I find I prefer the glitter for a bit of sparkle. I mix it to a thick peanut butter consistance and force it in the hole/cracks etc. I fill after turning and before sanding.
eliot
>I do like your answer, and I agree with you -- for the most part. But what I'm worrying about is a little different. I have been experimenting with making up my own wood blocks by gluing up 1/8 inch sheets of Home Depot cedar closet liner.( You have seen some of them.) So what we're dealing with are sheets of cedar wood chips that have been pressed together with heat and some kind of resin, or whatever and then glued up with ordinary yellow glue by me. The point is that there are voids all through the material, and they are not particular pleasing -- the way naturally occurring defects show up in wood in interesting ways. So I do want them smoothed out. I'll bring in my latest on to show you that it's quite smooth but that there are still small voids.
Paul Porter
Try coffee grounds and CA
Paul Porter
>The grounds should be used, dried and finely ground...force some into the voids, add a little thin CA and stand back. They are self accelerating and will smoke a little. Have a fan blowing across the lathe when you do this to keep from breathing the fumes.
GaryG in MD
>Eliot, Yeah, I see what you're doing. First, I would reco that you smear each sheet with some kind of filler before gluing on the next layer. You can sand it each time between layers, or not, depending on what you use as a filler and how you want it to look. A contrasting filler might make an interesting pattern (something like Stephen Gleasner's work with plywood). That way, if the voids are on the external surfaces, which many probably are, you'll fill them as you build up your block. If the voids are internal to the layers, they'll still be there and some will pop out when you turn the block. In that case, smearing the filler over the final form and sanding the residual off should take care of it. Bring it to the August meeting -- I'll be there unless my daughter decides to have her baby that weekend. ;-) ...Gary
eliot
>Gary, Shows what I know: I never heard of Stephen Gleasner. So I found his work on the Internet. and I am impressed. And it's odd that just last night I started thinking, in the light of the suggestion in the last post of using coffee grounds, of adding this coffee gruel --or something else -- to each layer as I glue them up -- just as you have suggested. I may even sand the layers to different thicknesses to increase the interest. So thanks to you and the others for getting me thinking in a new direction.
Mark Wollschlager
>Have you thought of using chalk dust mixed with a carrier ( CA or something else).
Someone at CAW used that to smooth and add color to a piece.
Perhaps you could find a color combination that would complement the cedar.
mark.
eliot
>It's getting spooky how great minds are thinking alike! Today I dug out some Behlen Fresco Colors, to do exactly what you are suggesting. I think this stuff may give a richer color than colored chalk, in that a small 2 oz jar cost $6.30, and that was quite a while ago. I just finished cutting up 30 rectangles of the cedar closet liner, each piece measuring about 6x6 x 7 inches, so I 'll have about a 6x6x7 inch block after it's glued up.( The "slices" are somewhat thicker that 1/8/in.) This time I sanded each piece on both sides at the sanding center to reduce the number of voids after it's glued up. I appreciate your interest.
Bill Hale / woodspinner
>Another way to do this is to sand but do not blow the dust out of the cracks. Go along and dab a little med. CA on all of the voids and sand with 100 grit sandpaper before the CA sets. The sanding will drive the CA snd sanding dust into the voids. When the CA has set resand and all should be smooooth.
May take a couple of trys but it does work.
Also black epoxy wiped in to the cracks looks great.
Good turning and be safe
Bill
