Goblet Jam chuck
Goblet Jam chuck
Goblet Jam chuck
Peter Hyde
>I am in the habit of turning a few goblets and doing a reverse chuck to finish the bottoms has always been a PITA. So today when the latest goblet needed reversing I took some time to think about what I needed and came up with this. It is 4" in diameter and the cone end shaped to the biggest and smallest goblet size. I put the bowl of the goblet on the cone and mark where it comes to then turn a step to a snug fit inside the bowl. Works great.In future I will have to turn the bowl rim to fit one of the steps but in the meantime this will be an on going process until the cone is just a series of steps.
Re: Goblet Jam chuck
Arch
>Peter, I'll belabor the obvious for turners less experienced than you. The vertical face of the step should provide most of the driving force and the horizontal circumference section of the step helps to steady and center the work. Compression against the vertical face is less likely to break a fragile goblet than expansion against the goblet's neck by the horizontal part of the step. My point is to be sure that the geometry of any short taper left on the goblet's neck or the step or both doesn't act to expand and fracture the neck as they are jammed together. Obvious, but has sometimes been overlooked.
