Elbow Hollowing Rig
Elbow Hollowing Rig
Elbow Hollowing Rig
eliot
>Anybody purchase this rig at AAW in Louisville? I got one and like most things about it. But there are a couple of problems I have. It is designed to attach to the tail stock quill; so, right off the bat, there is a limitation on height of vessel because the tail stock must be on the lathe, thereby crowding a tall vessel. Also, the clamp that attaches to the tail stock quill is not a precision device, so there can be problems getting the cutter tip precisely at the center line of the lathe. And there is no mechanism for adjusting the height of the rig. The Elbow guy (Stanley) sells an attachment that addresses both problems, but it's an extra $55. about a 25% add on. Kind of high. A fellow turner at my club made the obvious tail stock replacement with a height adjustment for his Elbow, but he is a Mercedes auto mechanic with a shop full of metal working tools. I suppose I could ask him to make me one, but it would probably cost at least $55. I may go for it, but you would think that the Elbow people would have included it as standard equipment. I can return the thing for a full refund, but, as I have said, I like most aspects of the tool. Any suggestions?
Re: Elbow Hollowing Rig
eliot
>Incidentally, you can find this thing at www.elbotool.com --- not 'elbow' )
Bill Hale
>I have one I bought at the desert roundup but have not used it much. At the onset of the tool the quil mounting piece was very weak and failed. I spoke several times with Stan and sugested a revision that he did and it is now as strong as needed.
When you set up the tool be sure to set the bolts on the swivel points as tight as you can and be able to move smoothly. If these are not set fairly tight you will get catches.
I feel it is a good sound tool with size limitations. Great for smaller vessels.
Good turning and be safe
Bill in Casa Grande, AZ.
eliot
>Bill, When you say ," at the onset ..", do you mean in an earlier version it was not so strong, and that, at your urging, it has since been improved for everyone. Or do you mean that you sent your particular one back to Stan, who improved it for you? In other words, do you think the one I purchased in Louisville is strong enough? Do you find that the clamp dings up the quill? Do you find that the height is right on?
David Galloway
>I have talked to a number of people in the Atlanta area who bought one at AAW. They are trying to convince me of its value but I am troubled by the size limitation. I found your concerns helpful. As I am a tool junkie, I will probably order one tomorrow, but am interested in other comments.
Bill Hale
>Elliot
I beieve the sales at the desert turning roundup were when they started marketing. I bought mine there and it failed. The next day at the seminar I returned it and talked to Stan about a way to correct the problem. The problem was in the way the weld was done and its' location. Stan agreed and a revision was made. Now that the weld was modified the mount is strong and it is a quality product.
Bill
Bill Hale
>Second part of question. I see no damage to the quill.
I find the height to be fine. The bars rest on the tool rest and you can set as you desire.
Bill
Bill Hale
>I found Stan to be a great guy to work with. I believe you will be happy with your purchase.
Bill
eliot
>One thing you could consider -- and I am thinking about it myself -- is to build a simple extension to your lathe bed. I don't mean anything fancy that you could slide a banjo or tail stock on; I mean just a flat plate with a bolt -on hold down. On the end of the plate you would attach a vertical column, which in turn would have a horizontal post that would take the place of the tail stock quill. At the same time, you could make the vertical column in such a way that you can adjust the height. This addition would both provide lathe extension and height adjustment. Stanley of Elbo Tools sells one for $55, which I think is a significant portion of the purchase price. So I'd say build it , if you have the tools. Then again, if his is well made, perhaps it's best to spring for the $55.
Gregory Whitney
>Bill, I believe Stan has come up with a needle bearing thrust washer upgrade for the original Elbo Tool special plastic thrust washers. The needle bearings allow you to adjust the tool joints more tightly and also give you a smoother cutting action. I don't see them priced on elbotool.com, so you may need to contact Stan to find out about them.
