3520B Powermatic
3520B Powermatic
3520B Powermatic
Roland B. Kuehn
>Black Bear, did you ever solve your clicking problem in your Headstock? What did it turn out to be?
Re: 3520B Powermatic
Black Bear
>Not sure yet. Tried everything that made sense that the kind people at WoodCentral recommended but nothing worked. Got in touch with the Powermatic Techies and they sent new bearings.
In the mean time, my company offered me a job in England (about 1/2 hours from Jimmy Clewes) so I have been over there looking for housing, schools, etc.
Will need to see if the bearings work before putting the Powermatic in storage for up to 3 years.
Thanx for inquiring.
Black Bear
Russ Fairfield
>Long term storage can be bad on bearings. Why not wait and replace the bearings in 3-years when you are going to use the lathe again??
don in central IL
>Or....you could 'store' it in my shop????????
Doug Thompson near Cleveland
>Black Bear, I missed your question in the past but had the same noise before. Remove the hand wheel then bend the tab down on the lock washer and tighten the nut a little bit. Run the spindle on high then slow it down and listen for the noise. The bearings are not bad so save them for later. BTW - Belt changes are easy too... 20 minutes.
Tim Grenville-Cleave
>Sneak the beast into your hand baggage and become the envy of all those northern turners here in the UK. Hmmmm the flyboys may have a cardiac if you put all those scary sharp tools in there as well though.
Rats! I guess the line forms here?....
Eddie Pacheco, San Jose, Ca.
