Advice for new Vicmark owner
gtwilkins
>No I don't want to hear sent it to _____!
As the owners manual is seems to be pretty straight forward (pictures I like it), are there any little quirks or nuances I need to know about, from any of you VL 300 owners out there before I get my new blue baby dirty! ( still can't think of a name yet)
The only queery I have comes from the back page in the Improtant Eclectrical Information section, paragraph 2 , mentions an RCD(for earth leakage safety) is this Australian for a GFCI breaker, anyone?
Thank You, Trevor
Re: Advice for new Vicmark owner
Fog Tanner
>Basicly that is what they are talking about. I read the same thing and had to do some research to find out I didn't need it. I have the Aussie Vl300 and ran a 220 line (10ga wire) and put a 20 amp receptical on it - no GFI/RCD. I don't really plan to turn when being flooded so I didn't worry about it.
Since you don't want to get it dirty, you might want to think about a couple of coats of car wax over the whole thing. I did that to keep any finishs from marking up the paint. I use some other lubricants on the ways to keep them looking new. After you run it for a little while, you may want to check the headstock. It will probably be a little warm to the touch, which is OK. If its uncomfortable, the bearings may need to be backed off a degree or two.
I have gotten into the habit of stopping mine by using the handwheel. I had to take the locking ring off as your fingers could get caught up in it. It is really for locking the chuck on and the hand wheel is a convient storage place. If you do many boxes you will find you will want a 6" rest, but the 30mm post is not very common. I am having one made for that reason.
The only things I have found wrong with mine, is there is a slight hesitation when I push start and the second is I didn't get it sooner. I also found that when I first started roughing box blanks down I would look at the rpm readout and it would be about 500-1000 rpms faster than what I should have been and no vibration like my old lathe.
