Tormak fixtures and jigs
eliot
>I bought several of these at at a woodworkers show, but I didn't get around to using them for a while; and now I'm not positive that I'm using them correctly. The instructions on the box are not sufficient, and my tech manual is an old one that doesn't show any of these newer devices. I tried the Sharp Tools internet link, which has a really good video demonstration, but it's only for bench chisels and plane irons, which I already do know how to sharpen. Can any happy Tormac fans help me out?
Re: Tormak fixtures and jigs
Rick Davenport
>I have a Tormek and I have almost all of the jigs.
It's hard to give advice unless I know which specific jigs you are talking about.
E-mail me if you have a specific question about a jig, I might be able to help.
My other job (besides turning wood) is sharpening knives for the local chefs in my area.
I have found no other device that sharpens kitchen knives so consistently and easily.
Since my Tormek is my cash cow, and since sharpening turning tools is so hard on my wheel, I now sharpen my turning tools with a Wolverine system.
The Tormek does a fantastic (if a bit slow) job on turning tools, but I want to get the most life out of my wheel.
RK in Milw
>You can download an up to date manual at www.tormekusa.com
eliot
>Rick and RK,
Thanks to you both. RK, the tormek download site was exactly what I needed.( I tried to find that site but was misspelling 'TORMEK'.)
Rick, I understand that you want to save the Toremk wheel for your knife sharpening; but which one, the Wolverine or the Tolrmek, do you believe gets turning tools sharper?
Tormek Yahoo Group *LINK*
Stuart Johnson
>There is a fairly active Yahoo group for Tormek users. Jeff Farris post regularly and is always willing to answer questions. He also has some downloadable videos on his web site.
http://www.sharptoolsusa.com/index.php
Tormek User Group
Rick Allen
>Hi Eliot
I sharpened on nothing but the tormek for 3 months (12/2005 - 2/2006). I couldn't detect any improvement in the way my turning tools worked. I switched back to the dry grinder, which most folks use, and I was unable to detect a difference in the way the turning tools worked.
All this to say that the Tormek may have put a sharper edge on my turning tools. But I was unable to detect any advantage at the lathe when my tools were sharpened using the tormek. There was one exception. The skew was sharper and I found the skew cut more effortlessly when sharpened on the tormek
There were several disadvantages with sharpening using the tormek.
Water. The tormek needs water, it need more and more water. Fill up the water reservoir, turn the machine on and watch the water level drop as the water in the reservoir is absorbed into the stone.
Clean-up. The tormek collects the waste from sharpening in the water reservoir. That waste has to be scraped out. Of course the Tormek doesn't collect all the waste. Naturally some of the waste ends up on the surface the tormek is placed on. And that waste is wet and requires additional clean up. And don't forget about the leather strop and the cream honing compound. That stuff gets tossed off and requires clean-up. Not to mention that the tool itself needs to be cleaned after sharpening so you don't transfer the metal particle laden honing cream to your woodturning.
Time. The Tormek takes a LOT more time than the dry grinder. I heard all the folks who are enamored with the tormek for sharpening turning tools talk about how quickly they could sharpen using the tormek "once the profile was set". The sharpening takes longer. At least 3 times as long. Add in the Gunga Din effort at the start and the clean-up after sharpening and I was adding several minutes to each sharpening session. Sharpening on a dry grinder is a necessary inconvenience. Sharpening on a tormek is a production.
Wheel wear. You have to be mindful of what the sharpening is doing to the soft grinding wheel. sharpening fingernail gouges is especially hard on the flatness of the wheel. You will want to be sure that you sharpen all your flat tools before shaping gouges as the wheel needs dressing before sharpening flat edge tools like a skew or bedan. There is a diamond wheel that you can get for the tormek. Turns out that this wheel is specifically counter indicated for "point source" sharpening. A long flat edge such as a knife sharpens without undue damage but a gouge where a small surface is in contact with the wheel while sharpening will wear the diamond coating off the wheel quickly.
Awkward to sharpen gouges. The angles that you hold the tool at to sharpening a bowl gouge are not well suited to the task. I tried both the top and back bar positions and found that both positions put you at a disadvantage when trying to control the sharpening process for gouges. The jigs for knives, skews and suck are well suited for the comfortable and controlled sharpening.
I found the tormek to be poorly suited to sharpening of turning tools
Good luck with your tormek efforts. I hope your results are more to your liking than mine were.
eliot
>Rick, You are definitely a prince to answer so completely. I'm a bit disappointed in your response because I just finished making the Norm Abrams dedicated Tormek sharpening station, and I have nearly all the jigs and fixtures. At the AAW in Louisville I also ordered their new sharpening guide especially made for turners(supposed to arrive in August -- about $22). I don't mind the cleanup, etc. but I am troubled that you don't find that the Tormek sharpens better (except for the skew.) Of course, there is the advantage with the Tormek that there is no heat and little stuff in the air. I recently have been experimenting with sharpening with three systems: the bench grinder/Wolverine, the TORMEK, and the Jool Tool. I realize that you may not know about the Jool Tool; it's a system of high speed rotating "Ninja" disks coated with various grits of 3M sandpaper, Trizact extremely fine abrasive(e.g. 5 micron), various "grits" of diamond, and very fine brushes. You can see through the rotating disks down to the tool your are sharpening as you sharpen. I, too, don't see much difference between the Wolverine and the Tormek -- again except for the skew -- but I am coming around to the conclusion that the Jool Tool sharpens best. The only problem with it is that it has to be done by hand --there are no jigs. So, for some tools, it takes about as much practice as turning with a skew. For others it's not bad. I plan to fool around with the Tormek for a while to see if I can get better at it -- and also the Jool Tool. But I have a sneaky suspicion that when all is said and done, I'll be over to the bench grinder/Wolverine to sharpen and get on with my turning. ( I have to add, though, that in Louisville, the English guy at Tormek vendors station sharpened turning tools on the Tormek with the use of the new guide very quickly, and the results appeared superb.)
Bill Hale
>OUCH Rick
I use only the Tormec for my gouge sharpening. I do the shapeing on a grinder. I find it to be fast, I don't wory about clean up,and I feel the tools last a lot longer due to a finer cut to sharpen.
Bill
Rick Davenport
>I think both systems will get your tools sharp enough for even the most particular turner.
The Tormek is much gentler and less aggressive.
Because of this, you may get longer tool life using the Tormek and you can be much, much more accurate.
Also, you run less risk of messing things up.
A fraction of a second of distraction or misguided pressure on a bench grinder and you can cause big problems.
But as has been said, it is slower and all of us are impatient.
We want to turn, sharpen and turn back to turning.
Now I want to get on my soap box about sharpening.
Show me a razor sharp edge on chef's knife and I will show you an edge so fragile that will roll over in minutes.
There is a compromise between sharpness and durability.
If I set my Tormek to a super thin, 30 degree bevel on a knife, that knife better be used for slicing and filleting, NOT chopping.
So beware, the constant search for the "sharpest" may be defeating the goal of most useful and apppropriate.
Just my opinion, and we all have them.
Rick
Rick Allen
>Hi Eliot
Your turning has been improving for the last few years. I like the shapes you are turning and the quality of your finish has steadly improving to the point that your finish is now consistantly VERY GOOD.
I doubt that improving the sharpness of your tools is going to have an impact on the growth in your turning. At the same time exploring new ways to sharpen your tools will likely not detract from your path of improvment.
Was that in the 3M booth, demoing of the JoolTool? One thing you can do to improve your JoolTool sharpening is to use a magic marker on the bevel. While you are sharpeing you will see the marker removed and that observation will help you adjust your angles.
You can also get rubber impegnated grinding wheels which will put a polish on your bevels. Grinding the heel off you gouges will improve how fine a cut you can make with a 1/2" bowl gouge while still rubbing the bevel. There are a lot of ways you can "adjust" your tools to improve your turning.
Still I am thinking that we should have spent more time in the rotations and less time at the trade show(;->)
eliot
>Rick,
Thank you for your words of encouragement! I'm sure you're right; I tend to get overly technical and analytical ( I think it's the wrong side of my brain.) I should be thinking more about design, etc.
As for ,"what was that "demoing" in the Jool Tool booth, I think you mean, "who was that!?". Her name is Annie, and she actually invented the tool. And , wow, you have to see her sharpen an Elsworth -type swept back gauge with it! I have a certain amount of trouble taking my eyes off her, to tell the truth (thus using ,perhaps, the correct side of my brain!) She was originally a jeweler and used the tool for jewelry and somehow got over to the woodworking community. She's lots of fun, very knowledgeable , and , to use her own words,"very hot!
Well said
Brad Thompson - Hartselle AL
>Rick,
Never a more profound and accurate statement could be made about sharpening. Well said.
... "Show me a razor sharp edge on chef's knife and I will show you an edge so fragile that will roll over in minutes.
There is a compromise between sharpness and durability. "...
After all, they are tools (even the chef's knife).
Brad
Re: Well said
Rick Davenport
>Thanks for the compliment Brad.
I can't count the number of times a chef has demanded razor sharp knives.
I usually ask him if he is going to shave with it or chop vegetables.
Which opens the door to discussing the proper bevel for his needs.
Rick
