Re: Glue for Wasteblocks
Fog Tanner
>I never use CA glue on a joint that is subject to shearing forces, that is the weakness of that type of glue. I have the same chuck and have been using Titebond I with no problems. I have been putting the waste block on just before I shutdown at night and it is OK the next morning. I make sure the two mating surfaces are flat, a film of glue on both surfaces, and then use the tailstock as a clamp. I have done both eccentric and offcenter using this glue with no problems. It just isn't water resistant like Titebond II and III.
I wish that the screw and the hole were six point so you could rotate the outside without having to use the faceplate. Not a problem for the eccentric, but a pain for the offcenter. Other than that it is a neat chuck, offering new opportunities for ways to ruin a perfectly good piece of wood, but then they are art and not really ruined - just a change in expression.....
