Need help with a dried pine bowl blank
Ken Langenberger
>I have it roughed out to 1 inch thick but it looks like a porcipine's butt.Should it be fire wood or should I keep trying? Would it help to soak it water?
appreciate the help thanks
Ken Langenberger
Re: Need help with a dried pine bowl blank
Allen Neighbors
>I've never seen a porcupine's butt, but I do know that pine requires really sharp tools, and light cuts to prevent tearout when finish turning. Not sure about the water, but I would think sealing it would be better... I use approximately a 35/65 percent mixture of lacquer and thinner.
Is that what you're looking for?
Allen
Keith Newton
>Which type of pine is it?
If it was winter, and your shop was really cold, you can soak then freeze some soft frizzy woods and get a real clean cut. However if it is as hot in your shop as it is in mine now, I am afraid that it would thaw before you could get started.
leo Van Der Loo
>Hi Ken you can go with Allens advice it's good advice or another one that helps some also, 50/50 water and white glue, soak for a half hour, take out and wipe clean, let dry for a couple of days, then turn, and make sure you slice the wood with your very sharp tools, it's a good way to learn how to hold your tools.
The glue or lacker/sealer will fill between the wood fibers, so they keep upright and it's easier to cut hem.
Have fun and take care
Leo Van Der Loo
merv Graham
>Two things I have tried with limited success. (the cheap way)A 1 liter spray bottle with a teaspoon of dish washing liquid and water; spray and cut til dry and repeat or required finish which ever comes first. 2 When the grain is real trouble some I use Claphams cutting liquid. This has been more successful but of course more expensive. Of course ditto on the sharp tools and proper shearing technique.
Barbara Gill, Remlik VA
>Ken, I have a little different opinion. Unless pine is the only wood you have or unless it is particularly beautiful or special I would toss it and practice on a nicer more turning friendly wood.
Life is too short to turn bad wood.
Barbara- that quote should be "crappy" wood!
Jamie Donaldson
Ditto....
Brad Thompson - Hartselle AL
Toss it and go on
georgetroy
Re: Toss it and go on
bob davis
>never give up
RobinCorell
>As a patternmaker I turned a lot of pine. We use sugar pine, and usually laminated so that you are always turning long grain. sometimes you still have to turn short grain or even end grain and that is where a toothing tool comes in handy.
the best were made by phelps mfg. of oakland CA and had an auminium handle. the one I have is made from an iron from an old toothing plane. the tool in the attached pic is 2" wide and is ground and used as a scraper. it can even be used on a face plate with out catching problems.
It is like holding 40 diamong point tools extremely close together. the tool works to shape very dificult grain in other woods as well. It leaves a surgase of fine ridges that clean up nicely with a regular scraper.
Since patternmakers don't turn the inside to shape or diminsion I have never seen or needed a round nosed toothing tool, but I suppose one could be ground that way. I have also seen single cut files ground down as skew toothing tools though I never felt comfotable borrowing these as I didn't know it they had been re tempered to a be less brittle.
Robin
picture of the working edge
RobinCorell
>her is a close up showing the working edge.
Robin
Re: This works on the outside?
>Sort of like a super scraper? Probably works much better than "shaping paper" (60 grit sandpaper).
I can't give John Jordan's real quote, been censor
LOL Here We Go Again :-).
>Back in Jan. we had the same discussion. I don't know when John Jordan came up with his version but mine was based on Richard Raffin.
The quote I was paraphrasing came from Turned Bowl Design printed in 1987,page 7. "Life is too short to expend valuable time on recalcitrant raw material."
I personally prefer "bad" to "crappy" and too many people get intimidated by words like "recalcitrant". :-) "Difficult" would probably be a better paraphase but I just like "bad".
