We value your privacy.
>Hi folks -- What do I need to do before staining to prevent the over-absorbtion of dye with the harsh results shown below? This is Behlen Solarlux Blood Red over maple, shown without lacquer and also after about a dozen sprayed coats. I do want to use a lacquer finish on this.
>You can dilute the dye heavily to any proportion until you get the shade you want. Solarlux sells a specific reducer, but you can use a wide variety of solvents including water, alcohol, acetone (very fast drying) and even lacquer thinner, according to Bob Flexner's Understanding Wood Finishing.
I assume you do still want it to accent the curly figure in the wood, but not so intensely.
>On a figured wood like that, you are going to get deeper colors in certain regions because of grain direction and the different densities. You can easily cut back the dye if you want a lighter color, or less intense if you will.
I use Liberons metalized dyes and you can cut them with water. Usually sand back a bit anyway, which cuts down any raising of the grain and them the darker areas will also stand out more because it (sanding) will lighten up the less intense area. You can also go back over it after sanding, with a different color, keep a color wheel handy to figure out what colors you are going to end up with.
Lacquer can be shot right over the top of most any dye, after it has sufficiently dried.
