New chuck jaws
New chuck jaws
New chuck jaws
>Speaking of Craft Supplies. I just got my new chuck jaws in the mail. Vicmarc apparently sells a full line of chuck jaws but many of them aren't imported here. Craft supplies is starting to carry some more of thier jaws so I ordered the 70mm jaws (3"). I have the 2" and 4" and often missed this size. The 70mm jaws are in the middle. On the right are my favorite jaws the extended jaws. These things are wonderful for all small stuff, especially christmas orament finials.
Re: New chuck jaws
Re: New chuck jaws
Jennifer@Indy.USA
>John, I can think of so many times when the extended jaws would have come in so handy.
Jen
Re: New chuck jaws
Re: New chuck jaws
>Jennifer They are great. They keep your hands away from the chuck and the hold really small pieces. I don't remember the smallest but it's close to 1/4". What I like the most is the rigidity.
Re: New chuck jaws
Vic jaws on a Nova
Phil Joines Krum, Tx
>The hole spacing is the same but the holes need to be drilled out and camphered to fit the Nova since it uses larger screws. I use a set of the extended jaws for small stuff. They will hold smaller pieces than the Nova pin jaws. BTW the Grizzly jaws are identical to the Vics but they only have two or three sizes.
Re: New chuck jaws
So, now
>you have to get ANOTHER vic chuck to keep from having to change jaws all the time . . . .
Re: New chuck jaws
Re: Vic jaws on a Nova
>Phil On my old Nova with Tommy bars the raised alignment rings are different. Just enough so putting the vic jaws on my Nova won't work.
Re: New chuck jaws
bob davis
>i have #1 grizzly jaws on my nova.had toenlarge countersink.may have adjusted ring on chuck slightly,..work great.this is anova 2 but jaws are same for all
Re: New chuck jaws
I have longed for ........
Jamie Donaldson
>...Stronghold jaws sized between #2 and #3, and wonder if these jaws can be modified to fit a Stronghold? On the SuperNova a size between #2 and #4 would very similar, but can they be fitted to either chuck?
Re: New chuck jaws
>John,
The tennons on the Griz jaws were a bit tight. Taking a few thousands off with a file did the trick. I don't have a Griz or Vic chuck so wasn't conserned about making it too small for them. There are probably some tolerance issues with the fit.
