sharpening help, please
Tom in Victoria
>I have little experience sharpening tools. I want to sharpen a FINGERNAIL profile on a lathe gouge. I have a good 1" belt/grinder but no bench grinder. Can someone point me in the right direction? I see WOLVERINE and SORBY jigs on the market but they seem pricey to me. Any help appreciated.
Re: sharpening help, please
Bob Fawcett
>Tom,
This jig is designed for a bench grinder, but you may be able to adapt it to your belt grinder.
http://aroundthewoods.com/sharp.shtml
Does your belt grinder have a platform?
Gouges can be sharpened by hand, but it takes a skill that is developed through practice. There may be a video at the woodcraft site here:
www.woodcraft.com/videos.aspx
Re: sharpening help, please *LINK*
>I would suggest getting this video. I shows 4 different techniques for sharpening. The method John Jordan shows for sharpening a bowl gouge on the grinder without a jig will also work quite well on your 1" belt sander. The various jigs might work on some 1" belt sanders but not most of them. The best bet for now is a grinder and the various jigs but your talking about a couple hundred dollars to do that. These systems will give you a very good edge with a short learning curve.
that being said I used a disc sander and belt sander to sharpen my tools for years before getting a grinder. It can be done.
http://www.woodturner.org/products/videos/fundamental_sharp/
ad de Crom
>Hi Tom.
Maybe is this a solution for you.
I use this for sharpening all my tools.
An old washing machine motor (runs in two directions)and a round disc with a round abrasive disc.
Easely to build
Tom in Victoria
>Can you give me some clue as to how you would accurately sharpen a FINGERNAIL profile on this setup?
merv Graham
>I agree this is a great video all members of the AAW got with their membership this year. I think it was worth the price of joining though for me it was a perk of being a continuing member. If you are in Victoria BC Canada and come over to Vancouver at all I could lend you my copy or better still you could join the AAW
tim mathis
>i use a 1" belt sander from leevalley. i found this web site on my search for the sharpest tools www.hdv.net click his tools and tips and spend some time he has some great ideas and easy to make tools that will save you a bundle.when i started turning i checked all the methods and this one was the best for me.the belts were cheap and lasted a long time.it has a toolrest that is fast and easily adjusted . between leevalley and klingspor's you can get great belts.and you can hone with this set up. and it works .i also made a buffer from the neighbors old dryer motor.basically i sharpen, hone, and turn . when the tool starts to dull i buff it with the buffer on the old dryer motor. and that gives me a scary sharp edge with a polished look .and it is very easy to do.i use the toolrest ,put the fingernail gouge on it set the angle to the belt and lock the toolrest down.then i start the belt grinder move the gouge to the belt and roll from side to side. it is fast and with a slowspeed motor on the belt grinder it will not remove much metal,and low heat.{the tools will last longer [removes less metal]} the bench grinder is a good way to go.i tried a freinds with the jigs ,good wheels, a truer for the wheels,a good slow speed grinder {why remove more metal than you have to.]i was between $350-$550. the very best way is the tormek which is very slow to do . and complicated at first but slow when you are turning and sharpening tools to continue turning.for the price and the speed of going from one grit to another and than honing with a leather belt to get a razor sharp edge this was and will be my choice. it just makes sense . tim mathis centerville ohio.
>Tim I have no problem with your method. I tend to use what I've got or jury rig something until I find that I can do it a better way, then I move on. Personally I don't hone the tools. I simply don't find it necessary. I don't have a problem with those who do. I started my turning career using various sanding methods to sharpen the tools. I now us a grinder because it works faster for me for all the different ways that I sharpen.
Glad you posted this. I think some will find it interesting and maybe useful.
Lan Brady
>Tim,
I really like your method for spindle tools where the cuts are short in distance. But on a bowl gouge, mine works better by having the hollow ground with 2 points touching the wood. a lot less sanding/cleanup.
Have you experieced this or not?
Thanks, Lan
Brad Vietje
Brad Vietje
>Um, Well, I don't get the same result...
The advantage of the hollow grind is the ease in hand honing with diamond hones. From a strictly technical POV, this shape is worse for the inside of the bowl, as the hollow shape of the bowl and the hollow shape of the bevel are opposed, and the heel of the tool scrapes more. You cam grind/polish the heel away so a smooth surface burnishes the wood as the gouge works, if you want. I find a flat bevel from a sand/buff system is faster and easier, but not as easy to hone -- thus a wash -- in practice, both methods woek fine.
RE: sharpening on a belt or strip sander -- If you get good results with the belt going down whith the flute upward (the usual woodworking direction), try reversing the belt rotation (can get longer belt and put a twist in it) and you'll get even better results. The belt (strip) rides on a thin cushion of air, so it actually bends around your cutting edge, causing a tiny round-over. Reversing the direction puts the round-over on the heel where it helps, and gives you a sharper edge.
Safe spinning,
Brad Vietje
Checking in from Stellafane -- www.stellafane.com
tim mathis
>Lan,
in my opinion the set-up i use along with honing and i think honing is the key, is that there is not much sanding, a honed gouge makes a cleaner cut.i use crown and sorby tools.they are made from good steel which will hold the edge longer. the tools that i have made from tool steel don't hold up as long between sharpening.this is what works for me i was tring to answer the original posters question about tring to sharpen on a 1"belt sander he had and was having problems with .his original post was on the messages board.some one told him to ask the question in the turning section.i used the wolverine jigs on a grinder when i found the web site hdv.net and tried the belt sander i was sold . my tools are very sharp and the rig i use is easy to use and it is cheap. don't get me wrong i was not looking for the cheapest way to do something. until i tried the tormek i was ready to buy the whole kit. the tormek is the king at sharpening ,alot of jigs, and slow. but the best.i have less than $100.00 in sander and belts, i did supply the motor. i have made bowls for gifts and there wasn't what i would call alot of sanding to them.again this is my opinion and what works best for me. tim in ohio.
Stellafane
Ed Karch
>Brad
How are the skys up there.
Ed
