swiveling tailstock *LINK*
>I've seen several devices for sale to supposedly swivel the tailstock out of the way. The ones that allow you to rotate the tailstock down seem a like a good way to go. The Robust lathe design is useful. I can't see how swiveling the taistock to the side does any good. When I need to remove the tailstock I need to get it completely out of my way not just to the side. Does anyone see an advantage to having the tailstock swing out the side?
http://turnrobust.com/Robust/Tilt_Away.htm
Re: swiveling tailstock *LINK*
Richard Allen
Richard Allen
>Hi John
If you want to gain access to the ways in order to slide a device on the ways like a second banjo or captive hollowing system large steady rest...
To get tge sharp end of the tailstock away from your elbow.
Most of these conditions can be achieved some other way. But slideing the devices on and off can often be the easiest way to mount or dismount a device. This is usualy done with the tailstock. I can see where a "parking lot" of swing away devices could be stored and retrived.
Primarly all systems for getting the tailstock out of the way replace the existing slide and lift system most of us use for the tailstock.
Fog Tanner
>John, I can see an advantage, only if you are the one making the device to swing off to the side..;-) Like you, when I need the tailstock out of the way it would be for hollowing and off to the side is of no use. That is also the reason I have the long bed Vic 300, I can normally leave it at the end of the bed. When I do have to move it from there, it is to a bench below the level of the bed. Robust does seem to have the most practical design in getting the tailstock out of the working plane.
The best I have seen was a small bench on casters, that had a set of wooden ways. The ways were at the same height as the lathe. It was rolled to the end of the lathe and locked, the tailstock slid onto it and then casters were unlocked and it was rolled out of the way.
Phil Powell
>John, I have a Robust 25 inch lathe with the tilt away tailstock. I use the tilt away
option every day. Originally I ordered the lathe without it but gave in to my better
judgement and added the tilt away. I'm really am glad I did I can't imagine using
this lathe without it. There are all kinds of answers to the problem of turners
elbow , however in my mind this is hands down the very best. You need to use
it before passing judgement. The Robust is a great lathe and the tilt away just
makes it better.
>Richard Good idea about getting the tailstock out of the way to install other devices. Very quick and lets you get the tailstock back in position very quickly. Of course so does the rotating rig. The downside of the rotating one is that you still have to lift at least some of the weight of the tailstock. I don't think anyone has designed one that tensions itself with a gas shock or some such thing so that you could lift it back in place with 2 fingers.
The swinging tailstock would not require lifting it just seems like it would get in my way more that it would be useful. Thanks for the insight.
Vicmarc.fan
>I have the Vermec swiveling tailstock on my Vicmark 300 shortbed. I have not had to remove the tailstock since I insalled the thing. If you have seen one you know the hinge is set back quite a ways so when you open the unit the tailstock WILL give you room to set up the secondary rest for hollowing. I also like the extra length the unit gives. I have not had to mount the extension for longer things. Anyone want to buy a extension for the Vic300 shortbed?
Ron
>Phil I wasn't putting down the Robust lathe design. I think that's the best one on the market. I was questioning the ones the swivel from inline to the side rather than rotating like the Robust does. There are all sorts of different turning techniques and someone who uses these things may be able to explain to me how great they are. They just don't seem to work for me. I'm curious and willing to learn. Of course curiosity killed the cat but hey I never was a cat fan anyway. uh oh now I've probably made someone mad. I'm a dog person but would never hurt a cat and have fed my share of the fuzzy little things.
Re: I just wish that....
JamieDonaldson
>...the Robust rotating tailstock holder could be mounted to my Stubby!It is by far the best design yet, and anything that improved the lifting of a Oneway tailstock would be a hernia reducer!!
Mike Brazeau
>I ordered one for my 2436 so that I can easily remove the banjo and move it to my 17" outboard where the lathe functions like a bowl lathe. It is much easier on the back for turning. Currently I resist doing it because of lifting the heavy tailstock. Obviously of interest to us of the older set, but looking around Louisville, I felt pretty young again!
Mike
Swinging Tailstock Holder
Carole Valentine
>Why John! If I didn't know better I would say you are doing the backstroke! ;)
>Carole I'm still you enough (or stupid enough) to just hoist the tailstock out of the way but I suspect that as the years go by I'm going to be seriously looking at these things.
>Mike years ago I demo's in Birmingham and they guy I stayed with had a Oneway. He had made a tube the same size as the Oneway with bed and everything. It was about a foot long. It rotated on a collar that was inserted in the Oneway bed. I don't remember if it locked at 90 degrees to the side or just swung down to 180 but it did lock in the upright position. This was extremely simple and effective. The Robust is the closest to that so far.
>John, I have a Nova DVR and I did not get a bed extension. (small shop blues) I made a swivel block that sits at the end of the ways and has a single bolt through one of the holes in the end of the bed. I tilt the tail stock over to the rear and it comes to rest with the quill (?) on the back of the counter top on the cabinet. There is often a pile of saw dust there to provide a nice soft landing pad. I shaped the piece of walnut I used for the support to allow the installation of other devices on the bed. So, I can tilt it out of the way and park it and easily install other things and tip it back up MUCH easier than removing it and setting it on the floor. I can park and put it on with one hand.
When I made it, I did not have a hollowing rig or a bowl steady. Maybe if I had, I would have thought of it more as a turret with a stock of tools waiting to be parked or loaded. Hmmm. What I'm saying is that I made mine in an afternoon and it is hugely better than not having one. It cost nothing but some time and scraps and I enjoy it and the lathe more than without it. Easy to use, much less lifting and strain. Maybe it could have been better and more versatile, but for what it is I like it. If I had built the turret, I would have to find some place else for my planer Which rolls around, but is supposed to be parked at the end of my lathe.
Phil Powell
>John, I certainly wasn't getting excited about your thoughts on the Robust. I was
just defending the tilt away tailstock option. There have been other postings here
discussing the silliness of that option. Brent (Robust owner) had machines at the
AAW meeting in Louisville and pretty much everyone that tried the tilt away wanted
one. I was lucky enough to be able to retire early and also lucky enough to be able
to purchase my "last" lathe. Wasn't cheap, but good tools never are. Good turning
to ya!
Brad Vietje
Photo Available ?
Brad Vietje
>Hey Ron,
I have not heard of that system -- could you find a pic or link to a web site that shows it ?
Thanks !
Brad Vietje
Newbury, VT
Russ Fairfield
>Personally I think these swinging and lowering devices are a waste of money. For about $50 more (at that time), I bought an extra banjo that stays on the outboard side of my Oneway and I never have to move anything except the tool rest. When I am using a hollowing set-up, I don't want the tailstock anywhere near the lathe. If I want to use the tailstock on the outboard side, I still have to lift it. When that is more than I can handle, I call my wife.
Re: Photo Available ?
Vicmarc.fan
>This is a Vermec photo they sent me.
Ron
Brad Vietje
Brad Vietje
>Excellent -- now that I see the pic, I have seen this... I like that the hinge plate extends a few inches out past the bed, so when swung out of the way, there is twice that distance of extra clearance. This looks like a pretty do-able home-built project.
Safe spinning,
Brad Vietje
Newbury, VT
