Vicmarc V belt
Mike Cunningham (Cape May NJ)
>Does anyone have a source, preferably in the U.S. and other than Craft Supply for the 690J V belt used on the Vicmarc VL 300. I don't have a problem with CS but need to find another source.
Thanks,
Mike
Vicmarc V belt
Thanks,
Mike
Re: Vicmarc V belt
Vicmarc.fan
>Why would you want another belt? They last so long most dealers don't stock them. I would try Vicmarc in Australia.
Ron
Re: Vicmarc V belt
TDaniel
>Ron, there is no interlock on the Vl300 to prevent a student from turning the lathe on with the spindle locked. This results in a burned out belt immediately. Vicmarc doesn't think this is a problem.
Re: Vicmarc V belt
>For a short period it was off-center and rubbed against the headstock wearing an edge.
Re: Vicmarc V belt
Vicmarc.fan
>I wish I had a dime for every time I have started my lathe with the spindle locked and I don't have a problem with the belt. With the number you have I would try a belt supply like Gates.
Re: Vicmarc V belt
>Well I never said that I started the lathe with the spindle locked, as a matter of fact I haven't. As I did say, the belt was rubbing the headstock housing and that's what caused the problem. CS is sending one to me but I was hoping that someone might be able to answer the simple question that I asked, which was. whether anyone had a source for the belt. At any rate, Gates doesn't stock them Thanks.
Re: Vicmarc V belt
Guy
>When I had my Nova 3000 I had to replace the belt and I went to the local auto parts store (NAPA). They didn't have the exact belt but had onethe same length but wider. Bought it and narrowed it by cutting a few ribs away. Haven't had to replace the belt on my Vicmarc but if I ever have to I'll try the same thing again. Good luck!! Guy
